![]() Join Date: Oct 2008
RB25 S14 Problems
OK so my RB25 S14 has had this problem ever since I swapped it.
After I get in it, sometimes the throttle doesnt respond to any input, and it slowly goes away, but I have to be out of the throttle for that time, or change gears helps. It also does it around corners, it just cuts out, then catches again. I made sure it wasnt my walbro pump. I put the stock sock back on it, and made sure everything was tight and it has power going to it. One thing I noticed tho when I spliced in the harness for the new pump, I just used butt connectors, but didnt seal them in any way, shud I seal them with shrink wrap or something? Also, when I did my harness conversion I read that the power wire for the injectors had to be given a direct key on 12v source. So what I did was tapped into my ignition relay by the ECU. I kinda rigged it and just stuck it into the part of the relay where the wires go in, wrapped it in electrical tape, and called it good? Shud I change this? Also the few times Ive tryed pushing the car past 10psi it just sputters, and backfires. Any help wud be rgeat guys, thanks.
95 S14-RB26DETT |
#3 | |
If your fuel pump wiring is not 100%, you will have a very difficult to diagnose problem with getting on the gas, due to low fuel pressure at times. I would make sure that every wire, at every junction, is 100% mechanically and electrically secure. Your problem could also be with your upper engine harness. It's true that Nissan wires their injectors to constant/fused +12V on the hot side and switches the ground, and if you correctly spliced the injector power wire into either pin 3 or 5 of the ECU relay, the injectors should fire normally. I'd be betting that the problem is elsewhere in the harness, and could definitely be an intermittent ground or sensor-ground problem. Like I said, difficult to diagnose, lots of possible causes. If you wanted to send the harness out to get it checked I could eliminate the upper harness as a cause and clean up your wiring, but I can't inspect the whole car's body harness or grounds from afar.
Well seeing as how my whole ahrness is put together with butt connectors thats the first thing Im fixing, and soldering and shrink wrapping everything.
95 S14-RB26DETT |
