Hey everyone. I?m looking for a functional S13 TCU. Please PM me if you have one available. Also if have pictures or videos of the TCU actually working that would be most appreciated. Thanks.
![]() Join Date: Jun 2003
Trader Rating: (129)
how are people damaging these??? I've sold 4 TCUs in the last month, and in 20 yrs of owning a 240 have never had one go bad.
#4 | |
Probably cutting a radio harness, or leaving bare wires when faced with unused functions during a radio install. Or mixing wires up, or testing them recklessly. I forget which one (light control?) but there's a wire in there that will burn a printed trace in your TCU if it shorts (to ground, I think). It can be mostly repaired with a soldered jumper. The dimmer might not work after, though. |
#5 | ||
@Mechincalmoron how do you prevent the previously cut radio harness from damaging other TCUs? |
#6 | |
https://www.nicoclub.com/archives/fi...sh-lights.html I think the "ground it out" option is assuming you have a bad tcu, and will instantly fry a good one. It also mentions there's a dimmer fuse, which could either blow instrument lights or just prevent dimming, depending on how it's wired. |
