Old 11-29-2011, 01:34 AM   #1
Driven08
Trader Rating: (354)
Driven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfection
Feedback Score: 354 reviews
Unhappy Brakes not working after Z32 Brake Swap?HELP!
I'm going to try to go into detail from what I remember.
To start, my car always had stock bmc and front 30mm Z32 calipers w/ ss lines. I did the rear ebrake set up with z32 calipers. I bought SS rear lines and after everything was bolted on(bleeders are all facing up), I installed a used 1" bmc that looked brand new on my existing booster. I then bench bled the bmc and started off bleeding from there.
After trying for a while, the front calipers wouldn't bleed and bleeders were completely dry(checked to see if they were clogged, ran a needle through them to be sure) and then I began again. Rear Z32 calipers work great but fronts don't do anything. I ended up rebuilding the front calipers and finding out the 1" wasn't working. I currently just put in a used AcDelco replacement bmc(1 1/16) and tried again(I have a brand new bmc on the side but I need the fitting so I didn't install yet btw). Now I did feed the front bleeders fluid and the fronts are now bleeding but the pistons on the front aren't functioning still.
I need help. What am I overlooking?
Cliff notes:
Installed rear z32 ebrake assembly, including calipers
Bench bled bmc
Rear's work, fronts don't grab(pistons stay in same position)
Tried another bmc, old one wasn't doing anything and I'm still in the same boat with the exception of the fronts bleeding but pistons aren't going anywhere.
Driven08 is offline   Reply With Quote
Old 11-29-2011, 02:25 AM   #2
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
so fluid comes out of the front bleeders but the pistons wont push the pads against the rotors? the pistons could be stuck in the bores. is the brake pedal height normal or does it sink to the floor? if the brake pedal is pretty high when your standing on it and the pistons still dont work, they are stuck on the bores.
rcdad123 is offline   Reply With Quote
Old 11-29-2011, 02:35 AM   #3
Driven08
Pedal is mushy. Front calipers worked great before rebuild. They just weren't working after I did the swap. I rebuilt them to reassure myself they were fine and all the pistons looked fine. No scoring.
Old 11-29-2011, 08:32 AM   #4
Sileighty_85
Sileighty_85's Avatar
didnt ready all of it,
Make sure bleeder valves are pointing upward
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-29-2011, 10:56 AM   #5
Driven08
Yeah they are facing upwards. Next step I'm taking is buying a Might Vac and hopefully that solves the issue. Should just be air in the system
Old 11-29-2011, 10:58 AM   #6
Adio
Adio's Avatar
Adio is an unknown quantity at this point
What disc are you using?
Adio is offline   Reply With Quote
Old 11-29-2011, 11:14 AM   #7
Memberofthe600hpkaclub
Memberofthe600hpkaclub's Avatar
Memberofthe600hpkaclub is an unknown quantity at this point
Urhmm did you start bleeding at the right rear then left rear then right front then left front
Memberofthe600hpkaclub is offline   Reply With Quote
Old 11-29-2011, 05:07 PM   #8
Driven08
slotted 30mm fronts and slotted rear z32 rotors
Yeah I did that then moved to the fronts to try to focus on why they weren't working. I'm trying the Mighty Vac Tonight though
Old 11-29-2011, 05:11 PM   #9
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
Send a message via ICQ to EDacIouSX Send a message via AIM to EDacIouSX Send a message via MSN to EDacIouSX Send a message via Yahoo to EDacIouSX
how did you rebuild it? Did you take the caliper halves apart and rebuild that or just swap in new bushings and pistons?
EDacIouSX is offline   Reply With Quote
Old 11-29-2011, 07:49 PM   #10
Driven08
Took pistons out while calipers were assembled, removed seals from inside,Dissasembled calipers, installed new seals and lubricated them with brake fluid and put it all together.
Old 11-30-2011, 12:15 PM   #11
Driven08
ok so problem solved. Bench bled the bmc again and used the Mighty Vac for a while on each calipers starting on the right rear and moving all the way around. Brakes are now fully functional but still need a little bleeding.
