![]() Join Date: Jun 2002
Well at the moment my car is stuck in my garage and won't turn over... Earlier i was driving had to get gas and when I went to restart it would not, push started it and was able to get home. The battery is fine I've checked the voltage, i've got power, radio works etc. So that would eliminate the alternator from being a suspect since it's charging the battery. Does that make my prime suspect the Starter? Or any other suggestions? I've already replaced the starter RELAY. If any one could give me some tips or other possible problems that'd be great!
does it turn over?
cause mine wouldn't start one day and it turned out to be the switch under the clutch that lets the car start with the clutch depressed. It wouldn't crank at all. |
#4 | |
Use a multimeter when you check the voltage while you turn the switch. You should get 12 volts out of the switch on the START position. If the switch is bad, then you won't get zip out of it...the ACC & ON position of the switch will still work, but not the START position. Anyhow, hope this helps... ID |
Checked the ignition switch and everything checks out okay same as the clutch switch, i've narrowed it down to the starter and just installed a new one, Seemed to solve the problem! Thanks for the help on narrowing it down to that! No more push starts woohoo!
![]() Join Date: Dec 2002
Go ahead and bypass the starter relay to take it out of the equation, less problems to worry about.
Wow, good job bumping a thread from 2004 for something that wasnt really even related to your question. Next time try the "Small Questions Thread," or google it first.
Baling Wire-The Duct Tape Of Champions |
