Whine under acceleration
95 SE with 113k stock KA+5spd
it almost sounds like a supercharger whine.. NEEEEE or an electric motor sort of sound... it only happens on the gas.. on the over run, or in neutral there is no sound.. revving the engine doesn't make the sound either, feels more speed dependant as well.. but if u go too fast the sound fades (or the rest of the NVH takes over heh) happens in any gear.. doesn't feel like the usual release bearing/throwout bearing or pilot bearing type of stuff to me.. ideas?
07 Cooper S (DD),95 240SX SE, 93 FD3S w/20B, 88 FC3S 13B-RE |
![]() Join Date: Aug 2002
i just have a similar problem too on my 91 240sx coupe that just started yesterday. i added power streering fluid (atf) this morning and just finished changing my oil and replaced with some thicker 10w-40 for summer.
the whine is still there and my car feels less torquey than usual. it usually feels strong, but on the freeway it feels really weak at 70mph. engine sounds like something is wrong or low on oil. i'm not sure if this is related to any accessories going out or clutch fan since the car doesn't feel strong as usual. anyone have a problem like this before? |
i'll chk the oil level in the tranny when I get a chance this wknd.. but it shifts fine no grinding or resistance it has an E-fan...
I'm pretty sure the sound is coming from the Diff
the diff COULD be welded yes.. but I asked some friends and they said their diffs didn't whine when welded... chances are the bearings are toast.. I don't know if it can be rebuilt?
do your tires chirp when your in a parkinglot turning? it could be that you need more fluid or its just the way the diff was welded.
