Old 06-30-2011, 09:14 PM   #1
iveexcaped3
iveexcaped3's Avatar
iveexcaped3 is an unknown quantity at this point
fuel injectors
what injectors fit in what motors with no modifications?
example
will sr20 injectors fit a ka24e?
ka24de in a ka24e?
stuff like that any help would be good thanks
iveexcaped3 is offline   Reply With Quote
Old 07-01-2011, 09:58 AM   #2
jdm213
jdm213's Avatar
jdm213 is an unknown quantity at this point
z32 fit in sr and sr fit in ka when your turboing them
jdm213 is offline   Reply With Quote
Old 07-01-2011, 01:31 PM   #3
iveexcaped3
so you can only swap when your turbo charging because of the stand alone or what?
Old 07-01-2011, 11:12 PM   #4
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
no dude ..
turbocharging = more air into engine.
more air needs more fuel.
bigger injectors = more fuel
and yes you will need some kind of tuning when you turbocharge a ka.
this thread wont give you any answers anyways man. try using google or the zilvia search engine. the world of injectors is very vast.
1992 240sx (RB20. [email protected])
eklips3 is offline   Reply With Quote
Old 07-02-2011, 08:33 PM   #5
iveexcaped3
i know turbo charging is more air in the cyl. meaning needs more gas so you swap to bigger injectors. the injectors are bad on my ka and i was wondering if i could switch to sr injectors without turbo charging. thats why i was mainly asking
Old 07-02-2011, 09:52 PM   #6
OkiDori17
OkiDori17 is an unknown quantity at this point
if you replace with bigger injectors you'll have to re-tune the ecu, but i do know KA injectors fit on the SR so i don't see why the SRs wont fit on the KA
if i were you though id just upgrade to some nice Deatsch Werks
'92 240sx w/'93 SR Blacktop /// '94 RX7 FD3S /// '11 370z RIP
OkiDori17 is offline   Reply With Quote
Old 07-03-2011, 12:04 AM   #7
iveexcaped3
thats what i was looking for. i didnt know if you had to flash the ecu or get a stand alone. there's always deals on sr20 injectors so i was gonna swoop some up if i didnt need to retune. thanks guys appreciate it
Old 07-03-2011, 12:21 AM   #8
army240
army240's Avatar
army240 is an unknown quantity at this point
Yes, you need to retune or a stand alone... KA are 270cc, and SR are 370cc... by retuning you will tell your ECU to inject 73% of his "normal" pulse width to inject the same quantity.
Frank
Life is a beat to beat
army240 is offline   Reply With Quote
Old 07-03-2011, 11:11 PM   #9
iveexcaped3
Ok. So both ka-e and ka-de injectors are the same right. Only difference is the head.
Old 07-03-2011, 11:15 PM   #10
Sileighty_85
Sileighty_85's Avatar
Wrong KA-E are Top Feed, KADE are Side feed, Totally different
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-03-2011, 11:38 PM   #11
S14DB
AFC #1
S14DB's Avatar
The KA was found in more cars than the 240sx. You can get the stock injectors from several more common cars like the Altima.
Old 07-04-2011, 01:50 AM   #12
iveexcaped3
Sileighty_85 thank you. just saved me some cash. pretty much you cant switch any injectors with each other with out tuning.
Old 07-04-2011, 02:18 AM   #13
240sohc
240sohc's Avatar
240sohc is an unknown quantity at this point
why not have your injectors tested and cleaned/calibrated. RC Engineering in Torrance does this service.
240sohc is offline   Reply With Quote
Old 07-04-2011, 07:08 AM   #14
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
i ran junkyard altama injectors for months with no problems and there only 2 bucks for as many as you can find
sort of
yup
you can use a safc if you must. but its not a good option really. ok if your not running any or much boost.. but its not really worth the money..
i would just junkyard some injectors and run them untill your ready to turbo. and then do it right.
i guess you could get a safc, a wideband and some sr injectors and try to squeeze alittle more power out of the ka.. but i doubt you would do anything but make your car run shitty.
Tantwoforty is offline   Reply With Quote
Old 07-04-2011, 10:18 AM   #15
iveexcaped3
When I took the fuel rail off all injectors were on the rail and as I went to put it on the parts table three fell and broke the plasic tips on them
Old 07-05-2011, 08:30 AM   #16
DeatschWerks
DeatschWerks's Avatar
DeatschWerks is making a name for him/her selfDeatschWerks is making a name for him/her self
Be sure you know what year the Z32 is you are pulling from. 90-94 300ZXs use Phase-I injectors. This year range covers most of Z32's imported to the states. The 95-96 Z32s use Phase-II, just like all of the KA and SRs.
You could also pull from a Q45. V8 = 2 sets of injectors, but you need to take the same precautions. The early Q45 came with Phase-I, too.
I would highly recommend getting any junk yard pulls checked and serviced before installing!
Chris @ DeatschWerks.com
Fueling Your Passion for Performance!
DeatschWerks is offline   Reply With Quote
Old 07-05-2011, 08:44 AM   #17
DeatschWerks
Just so you know...the Phase-I and Phase-II are not interchangeable.
You can run (and most do when they have to replace) a Phase-II in a Phase-I application with an adaptor kit. DeatschWerks.com | P1-P2 Sidefeed Injector Adapter Kit | DeatschWerks
