![]() Join Date: Sep 2007
drilling hole for crank angle sensor
hi guys im going to do my 5 speed swap next week and i got some problems. my car is a 96 ob2 240sx and i got a 93 ob1 tranny because s14 trannys are hard to come by.. i want my 240 to not throw a cel coz i dont want my car to fail the inspection so i want to drill a hole on the s13 tranny that i bought. so could somebody that has an s14 manual tranny make a measurement on the spot where i need to drill a hole coz im not really sure on the exact spot or somebody could make me like a stencil so itll be more accurate and i could pay for your service and the shipping.
this is the s14 crank angle sensor hole: and this where the crank angle sensor on the s13 supposed to be is: and this is what the stencil should be like: ill greatly appreciate you help.. . btw somebody told me that i could put a resistor to something to trick the ecu that i have the crank angle sensor but i cant find any info of it on here same thing with the wiring the check engine light to the abs light please let me know if you guys know how to do it. Last edited by icemhan_21; 04-30-2008 at 11:27 PM.. |
![]() Join Date: Aug 2005
or you can just wire your check engine light to your oil pressure light, and learn to read ECU codes, or check for ECU codes regularly to make sure ure running OK.
#3 | |
![]() Join Date: Dec 2006
or you could learn to read, or know what you are talking about. he wants his car to pass inspection. if the cell is lit up it doesnt matter if its wired to the left low beam bulb. when the scanner gets hooked up its still gonna pull the code and fail. |
#4 | |
edit: nvr mind ^he answered it already |
![]() Join Date: Sep 2006
.. obd2 i wouldnt try it. i did my 5spd swap last month on my 95 but i had a 96 trannny, best mod u can do on a auto... ive read somewhere u can drill it tho so your on the right trac..search for it. good luck. |
#6 | |
yeah i just need find out the exact spot to drill |
![]() Join Date: Dec 2003
it doesnt have to be that exact, just make sure it over the flywheel
"yo wheels are so sunk im gonna need an extension" "havin 1000 horses is like tryin to catch dinner with a rocket launcher" |
#9 | ||
![]() Join Date: Nov 2006
it just has to be parallel with the flywheel so it can read off of it. you can put the sensor of the side or bottom of the tranny even... as long as it can read off the flywheel.
![]() Quote:
#11 | |
Man w/ CTSV & a Car Seat
Big enough till the sensor fit? Dont you already have the sensor on hand??? |
Honestly, go buy a new one. They break a lot...last thing you wanna do is swap your old one in after its gets crushed in the tunnel while trying to get your old tranny off.
#14 | |
![]() Join Date: Sep 2003
I just checked my FSM ('96 model as well) and it gave me no dimensions. If you have any questions and need FSM info, hit me up.
In search of a Zenki S14 right side (passenger) fender and straight hood that are rust free. |
#15 | |
so your trying to say that the only place that i could drill is where the original spot on top of thebellhousing? thats where i want to drill a hole anyway so im just trying to find the diameter of the hole that i need to drill. |
Yes, use the OEM spot. That way no wires will be stretched or in harms way. I couldn't find anything about air gap. Get a set of calipers (the measuring tool, not brakes) and measure the outside diameter of the sensor at its thickest part wher it inserts to the tranny. Drill hole accordingly. What you need now is the location and I don't feel like removing my tranny to get the measurement, sorry bud.
#17 |
![]() Join Date: Dec 2004
Trader Rating: (58)
Just drill a hole in the right spot, put a washer around the sensor 'pole', and trim the one side so the mounting bolt goes through (washer is to compensate for the raised part on the obdII tranny), and tap the hole for the mount screw.
To easy. Not srue why you guys are turning this into more than it really should be. I've done 4 or 5 now that way, not a single one has had an issue. Call it lucky, call it what you want, but my way works.
#18 | |
thanks for the help man.. but should i put like 2 or three washers? and what do you mean tap the hole? |
#19 |
Trader Rating: (58)
i dunno, i just grab whatever washers I can out of the Wurth/Venmar bin at the shop. sorry for lack of actual numbers lol
tap as in, drill and tap the hole for that little 8mm bolt to screw into (like stock)
#20 |
![]() Join Date: Feb 2007
will it run without the cas hooked up? im doing this in a few weeks using an s13 tranny on my s14 and im kinda in the same position. if it still operates normal, ill just tear the bulb out of the cluster.
240's are a nagging bitch with a hot body..its worth all the bullshit to get a chance to ride it
#21 |
![]() Join Date: Dec 2002
Argh, search man. The crank position sensor's only job is to monitor misfire. You do not need it to run/operate the car, the only drawback will be a CEL. I've tossed dozens of them.
#22 |
fugg it use a template from ur previous tranny.. the old paper and pencil method... drill and tap.... done deall go to bed.
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
