95 240sx wheel wobble
I've done some searching and can't find anything similar to what I'm experiencing..
When I drive my car the two rear wheels "snake" ..that's the best way I could describe it, its like they're cambering in and out as I'm driving. I've tried different wheels, and even with no wheels it does the same thing. I just replaced a bad wheel bearing and it was doing this before, I thought the wheel bearing would fix it on the driver's side but it didn't and I've noticed its doing the same thing (but not as bad) on the passenger's side. Any ideas?
Take the wheel(s) off, then grab each of your suspension links/hub and see if there's any play. My guess is it's your RUCA.
Rock wha U jock and don't talk if U ain't got!!
Well I have been running megan coilovers that are pretty low with no alignment.. I've got some aftermarkets but I haven't got em on yet to get it aligned. and like an idiot I drove on it with no alignment like that.. the toe is in a little too. I'll check them out
I felt of all the arms and none of them have any play. But I put the car on jack stands and put it in gear to get a better look at what was happening and it looks like my whole caliper is moving and letting the rotor move, which i think is why the wheel is moving.
I failed to mention that the abs unit has been acting up.. sometimes it'll make a low roaring noise and the light will come on on the dash, it started doing this after I tried to do some donuts and whatnot.. i'm guessing it doesn't want the wheels spinning idk.
So I had a more experienced friend look at it and one of my axles is sticking out abt a 1/4 inch more than the other side. Idk how it happened but I think I'm about to pick up a chassis with a blown motor that's in a lot better shape than my car paint/body wise.. so I'm not too worried about it.
#8 | |
I've had issues with my S14 where the wheels would seem like they're way out of balance, or like something was loose causing the entire car to shimmy and more often than not it's a sign of my alignment being out of whack rather than an actual component failure. If you can imagine, when your alignment is off - especially in the rear, if you've got a good LSD or Welded Differential - your wheels are going to be fighting to go in the direction they're pointing. Eventually, they're going to start 'scrubbing' against the ground and 'figure out' how to go straight-ish. As they scrub, you'll get some vibrations since the tire is trying to slip against the pavement. If you're having a hard time visualizing this, go get an eraser and run it along an abrasive surface. You'll see that it wants to 'skip' or 'hop' rather than smoothly wearing away. |
#10 | |
the thing was I never felt anything, I drove this car multiple times at 60+ and it never wobbled or felt "squirrely".. i had to have someone following me to even catch what was going on
