Chilton repair manual worth it?
So I'm gonna attempt to remove the engine out of my s13 and was wondering if the chilton repair manual would explain in detail on how to go about doing this?
![]() Join Date: Jun 2003
Trader Rating: (129)
heres how you do it.
step 1: drain all fluids step 2: remove shifter step 3: disconnnect battery, then all wiring harness connectors and hang out of the way step 4: unbolt trans and motor mounts. step 5: yank the bitch. install is reverse of removal. |
![]() Join Date: May 2011
No man, that book is pointless all info can be found on here. That 30$ book is pointless you can yank the engine out in 30-45minutes, and install it bak in 1-2 hours it really is the easiest car to work on.
![]() Join Date: Apr 2010
i mean taking out sohc and putting in sohc
or dohc to dohc is fairly simple, i would imagine. but once you start dropping in rb or ls or vq then do some major homework |
Ya no ill just be putting in a sohc I want a dohc if I can find one for the right price but my budget is really slim I mean SLIM and I live in CA so finding one in a junkyard intact is mission impossible 4 lol
Did a search and found it skimmed through it a bit but didn't really find anything about removing the whole motor out either way though I could probably figure it out its the installing of the new motor I'm more or less concerned with but I'm sure it wont be to difficult
#9 | |
FSM + Chiltons gets shit done. I have both, all the information from rebuilding the engine to basic maintenance. If you haven't done an engine swap or that much automotive work they are big helps. Shit i'll still have mine open on the bench while i yank the engine out for the 4th or so time.
#15 | |
#17 |
I'd say it never hurts to have, I purchased one for $18 at my local auto parts store, havent used it yet, but hey who knows..As for haynes, they make the chilton manuals, just under another name. FSM + CHilton is def good for diagnostics and such. Also google one of the best sources around.
for an engine swap the chiltons helped me a lot on SOHC you can have the book right on your windshield while working on the car. cant do that with the computer. theres not to much to it at all. if i were you since you got the motor out maybe think about doing the timing chain
