![]() Join Date: Mar 2009
sr20 oiling problem after oil cooler/filter relocation install
My valve train is now creaking at higher rpm's, and ticks at idle. I believe I am not getting enough oil to my valve train. please give me some input. Oil pump going bad? I am using 10w30 oil. or possibly i have the lines hooked up backwards from inlet to outlet.
![]() Join Date: Jan 2007
Did you prime it after installing the cooler? Normall you install it then you un plug the ignitor etc and fuel pump fuse and just crank the engine until it fills up all the lines and the cooler. After that you add more oil to make it register as 'FULL' on your dip stick then you start it.
Also yes switch to a thicker oil you could do 10w40 at min. try to find 10w50 or 10w60 |
#9 | |
You are supposed to prime it without the car firing thats why you remove the ignitor and fuel pump fuse and then crank it a bunch. After that you check the oil add accordingly and you are good to go, that way the engine never sees an oil pressure drop/oil starvation while priming the lines and cooler. |
![]() Join Date: Aug 2006
You can just unplug the crank angle sensor, its faster. take a picture for reference of how your lines are routed. NVM ill probably see you today anyway... HAPPY BIRTHDAY ERIC!
PARTING/SELLING MY COUPE. PM ME. |
![]() Join Date: May 2005
![]() ![]() Feedback Score: 2 reviews
Do you have a thermostat anywhere inline with your cooler setup? If so he wouldnt be able to prime the system because the stat would be closed.
If he has no stat and didnt prime the system maybe air got routed to the head somehow. Pull the valve cover and bleed the lifters and clean out the oil squirters while you're at it. |
^^ yep! sounds like if you just do what some of these guys are saying you should be fine.
with a oil filter relocation, and oil cooler set up,.. i bet u would need everybit of 5 bottles |
#14 | |
If he has a true thermostat made for an oil cooler then that thermostat doesn't completely close. It stays just alittle open under opening temp and at opening temp it fully opens. The greddy oil cooler sandwich plate does this and thats how its supposed to work. Cheap t-stats are no good.
![]() JG's RB Silvia 2009 |
![]() Join Date: Nov 2007
you probably have air in your lifters if you didn't prime the lines before/during install.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
![]() Join Date: Jun 2002
One thing you guys have to be-aware when installing oil filter relocation to the SR20 is that you do not want to install the relocation TOO FAR away from the motor, when you do that it will lower the oil pressure of the system. Normally passenger side shock tower is the most you want to extend the oil filter relocation, anything further towards the front of the car will result in a loss of oil pressure (hence lifter might tick..).
![]() 909-594-3619 Business Hours: Mon-Fri 10am-6pm (Pacific) email: [email protected] http://www.phase2motortrend.com |
#20 | |
![]() Join Date: Sep 2009
#21 |
You can mount the cooler anywhere you want, it's the oil filter relocation units should stay near the passenger side shock tower area but not too far pass that point is recommended.
#22 |
so the donut style "sandwich" plate kind would be ok? i bought one for my ca18det years ago that simply moved the filter down 2 inches or so, and had the oil cooler lines in the sandwich plate... im assuming this would be the same style. thanks for clearing that up man. looks like i'll have a weekend project coming up.
#23 |
When you do install the cooler, becareful not to intsall too high above your motor either. This is sometimes an issue for externally mounted oilcoolers like in Sandrails and buggies, and an external pump is required.
Its common sense but make sure you connect your lines according to your engines Oil Flow, otherwise you will blow up. lol
#24 | |
![]() Join Date: May 2009
#25 | |
