93 gs300 cluster problem
ok so on my 1993 gs300 the overdrive doesntwork due to the gauge cluster. Its is a really weird problem, if you unplug the cluster the overdrive works , but as soon as you put it in, is burns out the left side of the whole cluster and ruins the cluster for good, and the overdrive stops working. any ideas? i have been told maybe a bad ground, can i make a secondary ground or what .....i went on lexus forums and no one knows shit, so i am forced to come to my good ol zilvians cause im sure someone on here knows better
