SAFC II question
I know it's sort of a 'newbie' question like usual.. but I just bought my friend's SAFC II from him.. to run with my car. Uh, my question is this.. I'm going to run a KA-T.. and I know that SAFC II can only handle 50% -/+ on a car, or for the injectors. I believe the stock injectors are 270cc? So, that makes the most it can handle.. a little bit over the 400cc range. My question is this.. this device is able to work on various different cars, so how exactly will it know how much it will be able to run? I mean, it's not like the SAFC II can know that the 'stock' injectors SHOULD be 270cc. I'm not trying to risk it and slap like some 550cc + injectors on there, but I'm just wondering..
#2 | |
If you hook it up right it won't throw codes. It sits between the mafs and ecu changing the signal sent to the ECU which in turn will cause the ECU richen or lean out the car based on the desired adjustment at each RPM interval. Obviously you can do serious damage if you don't know what you are doing but properly tuned and installed it will not throw a code. Also, I am not too sure about the 270cc -> 400cc thing you mentioned. It will raise or lower your AFR by +/- 50% not raise the maximum design flow rate of the injectors. If you're using a z32 mafs you're going to want to make sure you set the SAFC to be reading an actual z32 mafs but be sending the sr20 mafs to the ecu.
'92 G20 '96 240sx |
the way I understand it:
The S-AFC can tune out 50% of an injector's pulse. No, wait I didn't say that right. It can tune out pulse widths equal to 50% over the stock injector size. Get it? So, a car that comes stock with 270cc injectors; it can tune 405cc down to 270cc no problem. If your car comes stock with 440cc, then it can tune 660cc down to stock. Get it? From what I understand, anyway. I've seen people use 550cc injectors with a KA-T project and it seems to work with just an SAFC. So, I don't know for certain. |
Does anyone on Zilvia have a KA-T that is running a SAFC with bigger injectors than 370cc? If they do, please contribute anything. Standalone is out of the question right now, but I'll be getting that in the long run, so I don't wanna be getting an ecu upgrade.
![]() Join Date: Nov 2002
I run 550cc injectors (deastchwerks.com sidefeeds) and fuel is taken care of with just an safc2. People don't believe it is possible, but I'm not the only one that has done this... it is possible for sure... I had to make my z32 maf setting to 1 IN 6 OUT instead of 2 IN 5 OUT (recommended for s14 ecu to z32 mafs), but that may differ for you.
#10 | |
