vlsd 5-bolt bolts, size?
does anybody know what the specs of the vlsd 5-bolt bolts are, I need the nuts and bolts for the flange to axel connection, for a set of ten which I need, it is 59 bux at the dealer for just nuts and bolts. I tried the ones I took off my 6 bolt but they are a smaller diameter and I would think this is very important becasue if there is play (which there is) then it could snap something in hard acceleration or something, or if you have any of the right bolts let me know, but mostly I was wondering if someone has the specs, otherwise I have to take the die grinder and cut away at another shaft I have laying around and take that into napa or some store to size up. thanks if you can help.
