Thumping from vlsd in s13
Hey guys! I'm working to take my semi Haggard s13 hatch back to stock after the previous owner took poor care of her. I've gotten a lot of the problems sorted out, but recently after a bit of hooning my rear differential has been making a thumping sound when I reverse or when I rotate the driveshaft in the reverse direction. The previous owner claimed it had a vlsd, but couldn't definitely say which car it was from. Looking at it, I believe it's one of the later j30 or na z32 diffs, because it has the stock bolt pattern of 3 sets of 2 bolts. When I spin the tires with the car in neutral both rotate in the same direction and they lock up decently under hard acceleration. I've never had a vlsd before, and want to make sure I'm not running it dry of gear oil, but I also don't want to just dump some redline in and hope for the best. Thanks for the help guys
Sent from my Nexus 6P using Tapatalk
