![]() Join Date: Sep 2004
How low is "too" low?
My s13 is on silkroads and the fronts are as low as they can go and the back has alot more but where it sits now is perfect. I drive my car everyday but havnt driven it all summer since i got it out of paint and have been trying to finish up a bunch of misc stuff.
I just noticed yesterday that my oil pan is really close to the ground, I just wanted to see if anyone else oil pan is this close to the ground and if they had any problems with it. I dont ever want to hear it scrape the ground but im trying to avoid raising the car. the scrapes in the oil pan are from the car with the 16s and higher ride height |
Thats not that low because of the 18's. That oil pan wont dent in like a stock pan will either so you should be fine. "If sparks dont fly, your rides too high"
What is going into the side of your pan?
![]() nissan tech |
#14 | |
theyre 17s the kid who had the car before me had the oil pressure sensor for the gauge in the oil pan so when i replaced the oil pressure switch with the gauge sensor i just used the old switch to plug up the hole in the oil pan for now. |
#17 |
![]() Join Date: Apr 2006
get solid motor mounts so it lifts the motor a bit
also get some skirts and aero so you can get off the ground a bit on the other hand you can just get a street sign and drill some holes and mount it under your pan. -los
#23 |
as said a hundred times, that aint even close to being low. my sway bar is like 1" off the ground, so my oil pan is like 1.5" off the ground.
sddrift.com - smirkis - poweredbymax.net |
#24 |
![]() Join Date: Apr 2003
When you start scraping pan then it's too low. Make a skid plate or something. Car looks good tho.
Watch speed channel 12/9 @7.30PM for drifting at HIN! [email protected] IF you bought stuff from me write me a review HERE ||VEXMOTORSPORTS || DMAX-USA || RPS CLUTCH || BAB AUTOBODY|| |
#25 | |
nah...no aero maybe just oem, ive still got to put my lip on. im just going to make a skid plate. done |
#26 |
You could probably still fit a regular floor jack under there. I don't consider myself low... but for where I live, it's fucking low enough, and I can't fit a floor jack under my front end anymore... not even close.
#27 | |
http://mymiata.paladinmicro.com/CRALJack04.jpg this bad boy scrapes the bumper bumper when i put it under the car. |
