AC unit come out?
Hey guys Im wondering if you can take the AC unit out but still use the seat system of the climate control. The reason why I want this is because I want to be able to hide my battery up in the dash. I am re wiring my whole car so that there wont be any wire that you can see.. Is it possible to take out the AC and keep the heat?
Thanks! |
![]() Join Date: Nov 2013
The ac unit is under the hood, what you're talking about is the blower motor. So no.
Sent from my SCH-I535 using Tapatalk
'91 s13 (Drift Rocket Under Construction) 2000 civic Si Coupe (Daily) |
Maybe. Depends if you're willing to sacrifice your glove box, and the size and shape of your battery.
Lol. I've never done this before but; you could theoretically disconnect the hoses, and stuff the tubing to your passenger vents so you still have warm air blow on you. Because fuck passengers, driftcar.
all i would do is take the hose to the defrost. because i drive mine as a daily so i dont care about heat just defrost and then pull all my other hoses out and i bet i could find a spot then.
Sounds like you have a plan. Let me know how it works out, man.
![]() Join Date: Dec 2004
Trader Rating: (58)
Why not hide it in the trunk?
For an S14, if your referring to the A/C unit under the dash. More than likely, ayou need to remove the entire dash to remove the 2/3 units including the heater core, A/C and fan resistor.
Once the dash is out, and the main brace bar it is all pretty easy |
![]() Join Date: Feb 2012
Trader Rating: (37)
I don't see a battery ever being stuffed under the dash w/ all of the units in their respective place. I have personally ripped out my dashes on multiple s13's for what ever stupid reason and I just don't see it happening. Not even if you were to modify the glove box.
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
Put it in the trunk.
