![]() Join Date: Feb 2003
I just picked up an s14 with a built ka-t 75# injectors, z32 mafs, recirculated bov and it has a JWT tune for the correct parts and is also running an SAFC II. Car runs fine a little rich on WOT but runs pretty decent all around except the idle. Sometimes it will idle normally but usually idles pretty lumpy around 700rpm-750rpm. I am new to the SAFC and was wondering if there was a way to raise the idle 100rpm so it would idle normally. Any other suggestions why it would idle so low?
WRECKED. |
![]() Join Date: Dec 2004
Trader Rating: (58)
Take out your safc and trow it into ocean....that's the best thign you can do.
As far as a low idle, why not just raise your idle to solve it?
Trader Rating: (58)
So yes, he can easily raise the idle for now, and contact Clark about what his ECU has programed onto it.
Mildly offtopic, but still kinda on topic: I was under the impression that a good ROM tune coupled with an AFC or AVCR to fine tune was a good idea? If the suggestion is to throw the AFC into the ocean.. what would you use to further dial in the car, once the ECU is returned from whoever? I know JWT and Enthalpy's tunes are pretty spot on, but surely theres something out there to improve upon it?
#7 | ||
#8 | |
Trader Rating: (58)
Speaking of this, I really need to adapt a true wideband and a map sensor to my logging capability
