SR20 BOV Location
Basically I'm wondering where I can route my HKS BOV. I have an enthalpy tune for basic bolt ons and I had the BOV on the hit side pipe of my ISR piping kit and it has problems idling after I let off the gas. So I blocked off the BOV and it runs perfect. High boost pulls are great but it has compressor surge obviously because the air isn't released.
Basically I'm asking where can I mount the BOV and not run into any idling issues. I think I can do the cold pipe by the throttle body but I just want extra info before I weld it there and then have the same issue. |
Recirculate it like factory and you can put it wherever you want with no issues
#4 | |
![]() Join Date: May 2006
like this
18g and 20g turbo users click on me #/f/tech-talk/261219-18g-20g-turbo-users.html
#6 | |
The website says it has to be the HKS cover so no guarantees
You will have the issue no matter where the bov is unless it is recirculated.
Either recirculate it Or change to a blow through maf set up To answer the next question, look up blow through maf.
MRP Manufacturing |
That's the spirit
Ayy yo, who's mans is this?
MRP Manufacturing |
#14 | |
GM2 (SW/AW)
Just move the mass airflow sensor to after the BOV. So you can chirp at people all day.
I personally run a blow through setup.
![]() Join Date: Dec 2013
either recirculate or surge. my personal Z32 surges all day. N-Attack GTR Surges (actually most of the Corporate Race Cars surge for all the throttle responsies) I know personally of people going on 4+ years surging their T25's and T28's without issues (while i've also known people to seize turbos days after surging).
#16 | |
#17 |
![]() Join Date: May 2011
a small amount of surge wont hurt it, if your blocked completely its going to cause problems but if you have a little surge from the bov not releasing air fast enough its going to reduce the life of the turbo by such a minimal amount its not even really measurable, comp surge can mean multiple things almost all of which make the same noise but aren't all terrible, im running a hks bov recirced from my cold pipe about 6 inches from my throttle body and I have small amounts of comp surge and both sizes of the hks recirc fitting, Im using the smaller fitting because even though I get a little surge with it the response is very noticeable, there is no spool time between shifts at 15 psi and im running an open dump tube so its very noticeable, the screamer pipe is screaming before my foot hits the floor again after every shift where as with the larger fitting it takes a second to hit full boost again
#18 | |
MRP Manufacturing |
#19 |
#20 |
I have the ISR pipe kit that's modified to fit my high mount intercooler, but my BOV is on the hotside. Makes it easier for me honestly.. less hoses going across the car and what not.
#21 |
No, this is a very noticeable difference, its not something small that makes me feel better about myself lol its literally the difference between the wastegate opening a half a second after shifting or a full second after shifting, drifting is also much much easier, far less clutch kicking
#22 | |
That's how you properly install a blow off valve vented to atmosphere with no side effects and only benefits. /thread. |
#23 | |
#25 | |
And as far as cold pipe vs hot pipe closer to the compressor housing where you want to evacuate surge is always best but not always ideal due to packaging issues. |
#26 |
there really isn't any benefit to recirc on a map setup plus no recirc = cool pshhhh sounds, I would also say hot pipe as close to the turbo would be best if you can find a place to make it fit
#28 | |
![]() same car same setup Recric Greddy Type R bov ![]() ![]() ![]() |
#30 | |
MRP Manufacturing Last edited by KAT-PWR; 11-03-2016 at 04:22 PM.. |
