pros and cons of using a electric radiator fan
i was thinking about switching the radiator fan to an electric one...more specifically a black magic flexalite radiator fan that my friend has in his garage.... what are the pros and cons of doing this?? thanks!!
Pro's are that the fans generally look cleaner and don't rob engine power when it's hot, and they're usually small enough to mount where ever you please.
Con's are that you usually have to get some kind of electronic temperature sensor or controller to use them and if you leave your car on for long (and I mean long) times without the engine running you can drain the battery. IMO when I get the time I'm gonna get some electric fans. |
e fans dont cool my car or some pro drivers I know cars(while WOT drifting for a few minutes)... formula d drivers...they all convert back to oem fan and shroud. on sr20's...
for street it was fine..even street drifting..but 3rd gear wot for 3 minutes is rough. |
#6 | |
thanks thats what i was hearing, but the one here has a built in temp sensor with it so that might be what ill be doing to free up some power especially at idle.... |
Leave the Mech Fan.
Flex-A-Lites are super ratty. the slims chomp dicks too, they'll make your car overheat on the track because the fan shroud backs air up and becomes a restriction at high speeds. I run two SPAL 11 pulls because my shits V-mounted, but it was one of the most unnerving decisions I've made to pull out the clutch fan. |
![]() Join Date: Apr 2004
Where is the sensor located? Is it one of those that you insert into the radiator fins?
Those are terrible because they like to fall out. Use a good sensor mounted in the head. I, too, have FAL, but I don't have a choice with my setup. I would much prefer the OEM clutch fan with shoud. |
