![]() Join Date: Sep 2009
hello peeps .. now I did my reaserach and found out tons of info so dont tell me to search . I knoe that spl, kazaama ,or jic are hands down good shit.. but my question is since most aftermarket inners and outers are all basically s14 wouldnt that cause toe in /out problems since they are a bit longer to the point where u cant even adjust anymore? i ask because i was thinking of purchasing this kit FRSPORT 1123 Circuit Sports HTR-0134-HC Inner & Outer Tie Rod Combo S13/S14
now i knoe what ur saying that they suck true but even so would even this still cause length problems??? ive read you can cut down other inners to about 3/4" but i dont wanna cut .. i was also thinking of using cs inners with cs outers OEM style for reliability i just dont want length problems can anynone shed some light i really want to make a purchase .. keep in mind i dont have any fancy modded suspension im not trying to drift just tryna have nice things with an upgraded touch for peace of mind thank you ![]() |
![]() Join Date: Aug 2005
I just put some teins on and they fit fairly well. Just make sure the rack is perfectly center and you shouldn't have a problem. Unless those are longer for some reason.
![]() Join Date: Dec 2004
Trader Rating: (58)
It's your steering. Second most important behidn stopping
Get OEM or Parts store innres and outers if you don't want to worry about roll center.
#4 | ||
yea thats why i wanted to go for oe style but the aftermarket ones do look cool and the price wasnt bad i just wanted to see if anyone had any smiliar issues but i appreiciate ur words of wisdom |
Trader Rating: (58)
Consider aftermarket parts like facny peanut butter cups. Sure they may look good, sure they may taste ok, but they are NOT REECES's cups...ya know?
#7 | ||
![]() Join Date: Jun 2007
![]() ![]() As far as aligning the car goes, there are no issues whatsoever... and I like the improved feel of not having any rubber between my steering wheel and the road (minus urethane steering bushings). Like you, my car is only driven on the roads; with occasional spirited driving and trips to the strip. Best I can tell, the CS tie rod set is great bang for the buck! For a dedicated drift/circuit car; or one that will be driven aggressively more often than not- Then I'd recommend a more 'proven' unit such as PBM, Tein, Cusco etc. Quote:
Ha! Didn't realize this... Well played sir!
![]() Join Date: Jul 2007
Trader Rating: (18)
what brace is that bolted to the back of the flca? on the crossmember....
'92 HB HX35 rb25 - sold '89 Coupe GTX35 VVT-I 2JZ - yeah buddy |
Man w/ CTSV & a Car Seat
Keep an eye on that outer Mike. I'm running Megan's but they're exactly the same thing and the bearing on my passenger side is loose so I got some play and they're barely a year and half old.
#11 | ||
i think the way you have it set is wrong because the jam nut on the outer rod needs to sit flush all the way or it will break .thats where my question comes in if theese exact ones will make ur toe way off on an s13 becaus ive seen where they mount they look crooked and its suppose to be straight |
#12 | |
Trader Rating: (58)
Jam nuts on the arm adjuster are right, and the tie rod end 'bolt' is installed correctly as wll. I personally am not a fan of the cheaper Tie rod end rod ends, but they seem to work...
#13 | ||
Pretty sure I have them installed correctly; and the car is aligned exactly as needed with no toe issues ![]() ![]()
