Old 07-18-2012, 08:52 PM   #1
greenwood
greenwood's Avatar
greenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymore
Oil cooler mystery
My car was running hot on the highway after a fmic install. Around 210 even after ducting and a good fan setup. So I decided to install an oil cooler. I bought the following setup:
http://item.mobileweb.ebay.com/viewi...id=01814039272
The oil cooler itself is a 19 row cooler and is a nice design. I got everything setup, fired the car up, my oil pressure is normal as it was before the install and now the car runs at 195-200 on the highway on a hot day instead of 210. The weird part is I put my hand on the cooler it is cool to the touch. Both the return line and feed line from the oil filter are hot/warm.
Can the oil cooler be just that efficient. I figured there could be a blockage in the cooler itself, but being brand new and running the car 10 degrees cooler on the highway makes me believe this is not the case. I spent sometime wrapping my mind around this simple problem and that is what I have come up with. Any input is appreciated.
Thank you
greenwood is offline   Reply With Quote
