GTR Rearend in S15
Has anyone done this? I have an S15 that I am swapping in an RB26DETT into and I also have an R32 rear end complete. My plan, not sure if it is doable, but I want to drop my S15 rear end and unbolt the S15 helical and axles and brakes and swap over the R32 setup using the S15 rear sub-frame. Is this possible, I am seeing that the S15 has four supports for the diff, two at the back and two to the front. I am going to be using a Mckinney Motorsports install kit for the RB26 and also a Mckinney one piece driveshaft. Is this a bolt-on or has someone done this and it was a straigth swap? Let me know as soon as as I have already dropped the S15 rear-end and I am currently stripping the backend to attempt this. Luckily this is not a daily .
My other option, not sure if it is possible but to use the R32 rear sub-frame and use the entire diff, axles and hub/brake setup and be able to use my S15 spindles and also use my S15 arms and whatnot? Let me know and sorry if it has been discussed because I have searched but most of the info is for S13 GTR rearend swaps.
The S14 and S15 should be almost the same, so people with S14s can chime in.
