Over 500tq clutch users
Looking for feed back from those making at least 600hp 500tq in their SR 240.
Please tell me what clutch you have and what you like and what you dislike. As well as what type of driving you do. Before you say search I have. And posts are old that I found and filled with 300hp cars. So I'm looking for what people are using now at these power levels and what they like/dislike. Please be honest. Thanks.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98 |
#3 | |
![]() Join Date: Dec 2013
any ORC Twin Disk is good they hold plenty of torque, pricing is right around the same as OSGiken, but OSGiken has an office state side which means they'll have more support. your other option would be a JWT Flywheel and a Southbend Clutch for 350Z. the Aluminum 350Z flywheel uses a 250mm clutch disk area with both the SR20 and the Z33 clutch patterns drilled on to it. so you pair that up with a Southbend Six puck clutch and you'll be in business. however your pedal pressure will be pretty stiff so make sure you re-enforce your pedal bracket and fork. ATS makes solid clutches too, Skyline guys love them but they are unsprung so they are harsh, also if doing a gearbox swap (which at 500tq i imagine you are) if you have engagement issues you'll be on your own so don't do those. Excedy Twins I've made slip before at 440tq at the wheels so beware of those. and as usual if you need help with any of them or questions feel free to let me know i can hook you up. I'm currently testing an ACT on my SR20VET so I'll let you know if it can hold the 500tq not sure if it'll handle it haha. |
#4 | |
From what I have seen the OS Giken is only rated to 450TQ. Is this not accurate? Are you currently testing a ACT twin disk or a regular single act? Thanks for the reply
currently using an ACT Single. I had a subaru break 520tq at the wheels on their HD6 puck so we shall see what the Sr20 holds. |
![]() Join Date: Mar 2009
Last time I talked to the OsGiken office state side they were all about helping me until I told them my application was an OsGiken clutch for my sr20 that I had purchased from OsGiken Japan. I received a reply of: "Sorry since we don't offer that clutch stateside, and you must have bought it grey market, we cannot help you any further with questions for this clutch." Real cool..
Aside from that nonsense OsGiken make the best clutches imo. |
![]() Join Date: Oct 2004
I have an Ogura 709d twin disc that holds like 700 ftlbs. I think their naming convention is like that...
Its discontinued, but Rhdjapan was able to get the part from Ogura.... They have 3 or 4 disc plates and carbons... Either way, RHDJapan does a good job on ordering the stuff.
Turn and Burn!
I run a act twin disc on my sr22vet making 667whp / 560 tq and it holds the power no problem.
However I really don't like the clutch and plan to try a os giken twin. Clutch pedal pressure and engagement is brutal and the chattering on decel is really bad. Ran a act 6 puck before the twin disc, it was much nicer but couldn't hold the power. |
I appreciate the feedback on some clutches.
I'm honestly not really interested in any of the 7.25 mini twins. They are too harsh and ruin transmissions. If a clutch is not longer available or not available in the states that doesn't really appeal to me either. Finding that right clutch is the hardest part of the car. Went thru several on my Talom before I found the one I like.
#10 | |
-Juan |
#11 | |
I have no problem at all bending over backwards for my customers, and making sure you guys are 100% content. this goes for anything from OEM parts to a full on build. I've been on log me in sessions and face time with customers before it's not uncommon to help them out with their situations. Because they support our company and keep our doors open. However when you go out looking for the best deal and not purchase from me why should we take time our of our day and busy schedule to provide service and support to someone who doesn't support our business? Same principle goes to OSGiken USA, it cost them money to keep their doors open state side and support USA customers. when you bypass them and purchase directly through RHDjapan or companies of that sort you are providing zero support to the USA branch. (this is part of the reason HKS USA closed down back in 2006) I know it sounds mean, probably selfish but it's true. we cannot keep wasting our time providing service and support to consumers who don't support our business. I loose OSGiken & ORC sales to RHDJapan 99% of the time due to the price difference but all of those customers have zero state side support. |
#13 | |
Ok, I understand where you are coming from. But from the way the guy made it sound I wouldn't have been able to buy an sr twin disc from OSG Usa anyways because they "do not offer this clutch in USA". Sent from my iPhone using Tapatalk |
Sorry to bump a old thread, I am looking to run a JWT flywheel with 350z clutch but can't seem to find a JWT flywheel for sale. Does anyone know another flywheel that will work with a 350z clutch? or the best clutch option on a sr20 making 600+ tq? Thanks in advance.
Hey man, appreciate the info. I should have mentioned I talked with JWT and they have no stock and don't plan to make it until next fall. I emailed Juan, hoping he has better news for me.
#20 |
RPS Max won’t handle 500. I made 360 on an old setup and it started slipping a bit with sticky tires and a prepped surface. Drag racing that is. You may be able to skate by in a Motorsport with less drivetrain shock.
My SR20VET |
#22 |
![]() Join Date: Jun 2003
Trader Rating: (129)
Automatics.
#24 |
American muscle also have the luxury of having huge flywheels with large surface areas. We are limited to what we can squeeze in the bell housing. A 350Z flywheel and clutch setup would be a good place to start with an SR transmission. I have a twin disk Exedy and it holds my power levels fine. However, I do have to slip it pretty badly to prevent bogging at the line. Hoping a tune/launch control will correct that. It is extremely hard to slip a twin.
And as Brndck stated, all the fast and modern guys are running autos.
My SR20VET |
#25 |
looks like a lot of the same brands are used with them too doing a google search...i had a talk a long time ago with a clutch rebuilder who advised he can replace the clutch material with things like felt, Kevlar etc for better grip...not sure if anyone has experience with things like this not off the shelf too...
#26 |
![]() Join Date: Aug 2008
I’m not making over 500tq but I have the Spec Stage 3+ on my SR and it’s been great so far.
It’s full face disc that’s sprung. Pedal feel is good and it hooks and hold very well for me. Think it rated for 900tq. |
