![]() Join Date: Feb 2010
Sr20det FPR vacuum port?
I'm trying to figure out which vac port to use for the fuel pressure regulator. It's an s13 sr20det with greddy style intake manifold. As you can see in the pic one port I need to get a nipple for. But those are the only vac sources at the TB. I have 3 nor vac sources under the plenum which one I'm using your map sensor. Other 2 are free. Thanks for any info guys.
uploadfromtaptalk1392864808396.jpg Sent from my SAMSUNG-SGH-I337 using Tapatalk |
There should be a port that's behind the throttle plate for the FPR.
NismotronicSA - Speed-Density Tuning for Nissans |
Only vacuum sources I have near the throttle body are the three shown in the first picture. One looks to be going directly into the throttle body and the other two are behind the throttle on the actual manifold itself.
![]() Join Date: Sep 2005
if you look at the bottom nipple on the throttle body, you can see that it is, in front of the throttle plate. We call this a boost only source. Even though that is incorrect, it sees vacuum when the throttle plate is cracked open. Not what you want for the fpr vacuum.
Cotbu is correct. Any source AT the throttle body is considered a "boost" source only. Some of those lines on your TB are coolant ports as well, not sources at all.
My SR20VET |
#9 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
There should be three ports on the bottom of the Freddy manifold too. 1/8" NPT thread. Get a nipple and run a dedicated line for the FPR.
