Sr20 running dangerously lean. Need some help
So I am having this problem for quite sometime now. I have been on nico and they cant figure it so I decided to give yall a try. Heres my situation. My car is running REALLY lean at all rpms. I took it to a good shop here in VA and everything checked out fine. They checked for vac leaks, the maf, injectors, tps, and they threw my car on the dyno to get air fuel readings. This is what they ended up getting.
RPM Air fuel ratio 1500- 17.7 2000- 16.5 2500- 16 3000- 14.5 3500- 13.8 4000- 13.6 4500- 13.5 5000- 13 5500- 12.8 6000- 12.5 At idle my wide band wont even read and when I am at crusing speeds it wont read till I hit the gas more then half way Now my set up I am running is a s14sr. With S15 turbo, all new exhaust gaskets and intake gaskets, z32 maf, 740cc injectors, tomei fpr, z32 fuel filter, 255 walbora fuel pump, hks bov, greddy front mount, and JWT ecu. See I dont get how Im running so lean when everything checks out. Could it be my tune? Any ideas on what to check next would be great. |
No I do now have an exhaust leak. And My spark plugs are straight white/leanish color. Fuel pressure is all correct too atleast what I read online. 38psi at idle and 43 with the vaccum unplug.
Have you heard of people getting bad rom tunes from JWT? |
![]() Join Date: May 2008
No, I've never heard of a bad JWT tune. It also could be a bad cooling temp sensor, telling the engine is too hot, but it would be a long shot... what's the voltage of your temp sensor at ECU? Give us the reading with cold coolant and at normal operating temperature!
EDIT : Check the resistance of the sensor, according to the FSM, it should be 2.1K to 2.9K @ 20 Celcius, 680ohms to 1k @ 50 celcius, and 300 to 330 ohms @ 80 Celcius. Frank Last edited by army240; 04-05-2010 at 07:08 PM.. Reason: more info |
![]() Join Date: Mar 2006
Unless I misread, that AFR info is useless, because we don't know what the load on the engine is.
If that is under vacuum, then you are running very rich at high RPM, but if it is under heavy load, then you are scary lean in the midrange
![]() Daily driven |
Man w/ CTSV & a Car Seat
Hmm...do you have a fuel pressure gauge? I'd check that and make sure you're getting good pressure when the boost starts building. Since you have a Nismo/Tomei one, that shit have a tendency to leak and not bump your pressure when its under load. My shit was leaking vacuum around the top hat area, basically it was leaking around the crimped area. Look at it and you'll realize what I'm talking about.
I pressurized my vacuum lines and found air leaking thru my FPR. I then JBwelded the fuck out of it to keep it from leaking again. |
Yup I have an electronic one and a inline gauge. And the fuel pressure looks ok. What is it suppose to rise too under a load? And ill check for a leak here in a little bit.
#12 | |
The fuel pressure should rise 1:1 with boost. So 43.5 with the car at 0 boost. ~36 psi for a stock SR at idle (about 7 psi vacuum) and then rising 1 psi per 1 psi boost. So for 14 psi boost, you should see ~57.5 psi fuel pressure
