Sr20det Engine Build
I recently bought a 93 240sx with sr swap. Below is a list of what has been done to the engine.
Sr20det redtop Stock con rods (i believe will be asking) Stock T25 turbo @ stock boost 7lbs Stock injectors Stock ecu with a Apexi Neo wired in but no tuning done with it wiseco 9.0 compression pistons acl conrod bearings acl main bearings acl thrust washer arp head studs and main studs Cosworth head gasket tomei 256 cams new rocker arms new vvl lifters rocker arm stoppers arp con rod bolts new isis water pump new stock maf sensor front mount intercooler walbro 255 fuel pump, full 3 inch exhaust and downpipe What kind of performance can i expect from this motor? Is this motor built well parts wise (hoping the guy that built it knew what he was doing) im not having any issues with it just want to know the pros and cons to what he has done with the engine. It is currently running on stock boost. What would be the estimated hp/tq at stock boost if that is possible to answer? |
![]() Join Date: Jul 2005
180rwhp the way it sits if the t-25 is newish
I would drive it at least 1 year, perform one compression test, and change the oil often is the most important thing. Listen for piston slap to help verify it has those forged pistons installed (are you sure they are in there?). If it stays together for at least a year, oil looking clean, then think about modifying it. |
Engine re-builds mean low mileage. If it was done right it should last a long time. If it has real forged pistons that also means you can raise the power to 400rwhp for a long time. A stock piston engine would want to stop around 350.
your first step however is verify the forged piston install. Look down the spark plug hole and try to read the top of the pistons for numbers. - Do a compression test. |
