Old 01-18-2007, 10:01 PM   #1
1 88 U
1 88 U's Avatar
1 88 U is making his/her stupidity well-known1 88 U is making his/her stupidity well-known1 88 U is making his/her stupidity well-known1 88 U is making his/her stupidity well-known
3 Clutch Pedel Problems
First problem is the clutch pedel will not return. If I press the pedel all the way down it won't return unless I manually lift the pedel halfway then the spring takes over. I bleed the system but no change.
Second problem is before the pedel completely died on me the clutch wouldn't fully engage so I couldn't get into gear. Miraculously I was able to time it right to force it into 3rd and make it back to the garage. After I bled the system I noticed the S.C. was only pushing the pivot about 1/3 inch.
Third problem is before the above problems occured I was encountering a click, pop when I would depress the clutch all the way and the car occationally wouldn't crank on the first press. With these latest problems with my clutch I finally decided to investigate to find the pedel was hitting stopper on the corner then sliding off rather than hitting it in the center. I roted the stopper around to a fresh side that hasn't been warn from the pedel sliding off the side and now the pedel won't reach enough to press the crank switch wtf. I know I can easily adjust the crank switch closer to the pedel but how in the hell could this of happened in the first place? It doesn't appear that anything is bent, shifted or loose to my knowledge.
Any input would be greatly appreciated, thanks ahead of time.
1 88 U is offline   Reply With Quote
Old 01-18-2007, 11:51 PM   #2
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Did you check for slave cylinder leaks or the slave cylinder at all? That thing caused alot of problems for me, I just got a rebuild kit, and it feels fine now.
I was having marginal clutch return issues.
Old 01-19-2007, 02:19 AM   #3
Sileighty_85
Sileighty_85's Avatar
Yeah rebuild the Clutch M.S. and the Slave and if the clutch isnt disengageing completely under the dash where the clutch pedal connects to the Clutch MS there should be a threaded rod that you can adjust your "throw" for the Slave Turn it all the way out till your clutch disengages completely but becarful not too much so it doesnt run out of threads and falls off.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-19-2007, 05:54 AM   #4
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
Don't rebuild the MC and Slave. Just get new ones for less than 50 bucks.
Also when you adjust the MC pushrod as previously mentioned......DO NOT adjust it ALL the way out. you should have 1/4" to 1/2" of pedal freeplay before clutch disengagement.
As far as your bleeding techniques, have you removed the dampener setup yet? Search for clutch dampener removal here on tech talk to get details. Makes the bleeding procedure 5 min. as opposd to 1 hour.
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
Old 01-19-2007, 06:39 AM   #5
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
Go to Taka Motorsports and get a braided clutch line. It will go straight from the master to the slave cylinder, and replaces the hardline, flexline, clutch damper and loop.
I highly recommnd it.
g6civcx is offline   Reply With Quote
Old 01-19-2007, 08:08 AM   #6
1 88 U
1 88 U's Avatar
No leaks.
Yeah I'm just gonna replace them. I attempted to remove the dampener a while back but stripped a nut and gave up, but when I replace the system I will definately do so.
What sucks is I bought the regular line for my project car about 6 months ago and if I had known they where gonna make the full MC to SC line I would have waited. I wonder if its a type o but on the page the price is listed $65 for s13/14 but everyother car is listed $35?
Ok so replacing the MC & SC, removing the dampener box, bleeding the system, then re-adjusting the pedel stroke should solve the dead pedel problem? Does anyone have an explaination for problem 3? I really can't figure out how the pedel all of the sudden wouldn't reach the ignition switch and why the pedel is sliding off the corner of the stopper.
Old 01-19-2007, 08:49 AM   #7
cdlong
cdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud of
Send a message via AIM to cdlong
is the rubber stopper symetrical? maybe it's thicker on the new side or something. it doesn't really matter, just adjust it and move on. sometimes things just get out of wack.
cdlong is offline   Reply With Quote
Old 01-19-2007, 09:34 AM   #8
Dream240
Dream240's Avatar
Did it, have it , love it.
1 88 U, can you post pics of the clutch pedal and it's stops? Both the forward and backward stops? Maybe you have a loose mounting bolt somewhere on the clutch assembly. Also have you ever replaced the white plastic u piece that goes in between the pedal assembly and the clutch pedal return spring? If not, maybe it's borken off and a piece is jammed up in there causing it to bind. Plus that would explain your creaking and popping noises. Those little plastic pieces are 4 bucks from the dealer and worth every penny.
Old 01-19-2007, 09:53 AM   #9
1 88 U
1 88 U's Avatar
I forgot to mention that I found the U piece floating in the return spring. I removed it and meant to post pictures to find out what it was so thanks.
Old 01-19-2007, 11:01 AM   #10
1 88 U
1 88 U's Avatar
Any bad words for AutoZone's Brakeware MC and SC?
Old 01-19-2007, 11:10 AM   #11
Dream240
Dream240's Avatar
I think I went with this setup.
http://cgi.ebay.com/ebaymotors/91-98...QQcmdZViewItem
Really they're all pretty much OEM replacements. Shoudln't have a problem as long as you keep the receipt for defects.
GL
Old 05-16-2007, 02:24 AM   #12
hsoj_v
hsoj_v's Avatar
hsoj_v is on a distinguished road
Send a message via AIM to hsoj_v
I've been having this problem too...
I changed the MC & SC also I've bled the Clutch Lines.
I took out the whole pedal to check the plastic pieces and they all seem to be in place. Still the pedal just slams to the floor when I step on it.
There is no resistance at all in the pedal.
hsoj_v is offline   Reply With Quote
Old 05-16-2007, 02:35 AM   #13
johngriff
johngriff's Avatar
johngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfection
Send a message via AIM to johngriff
Make sure.
1 Bench bleed the master cylinder. (search google)
2 Over Adjust the pedal on initial setup
3 Bleed the line
Notes: Any -3 SS Line will work, you just need the -3/m10x1.25(am i wrong on the adapter??). The price on the taka line is just right.
AutoZone Master works great. I would go with the Nismo Slave though. Creature of personal preference.
[email protected]
johngriff is offline   Reply With Quote
Old 05-16-2007, 09:00 AM   #14
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
SPL sells the SS clutch line for $20, or something.
Old 05-16-2007, 09:51 AM   #15
Dream240
Dream240's Avatar
That's for the small rubber replacement section. The entire MC to SC line is around 75 IIRC. But worth it, and cleaner.
Old 05-16-2007, 10:24 AM   #16
smurfgcr
smurfgcr is making a name for him/her selfsmurfgcr is making a name for him/her self
your gonna want to go to nissan and buy that little plastic "u" and possibly a new clutch assist spring. i had major dead pedal at one point in time and replacing those along with removing the damnper fixed my problem. just to let you know though, you are going to have a major battle trying to pop the spring back into place.
smurfgcr is offline   Reply With Quote
Old 05-16-2007, 11:07 AM   #17
Dream240
Dream240's Avatar
It's really not that hard if you pull the clutch pedal assembly out of the car. Takes a little elbow grease but shouldn't be too bad. Also remember to regrease the spring and pedal stops so that you eliminate any areas of possible rust, squeak, wear etc.
GL
Old 05-16-2007, 02:50 PM   #18
hsoj_v
hsoj_v's Avatar
So is the problem really that I need a SS line?
Old 05-16-2007, 03:24 PM   #19
hsoj_v
hsoj_v's Avatar
GL
Yeah, I took out the whole clutch pedal assem. out and everything looked fine to me. I regreased the pivot points where the springs ends meet the plasic "o's" and where the spring "u" meets the hook for the pedal.
When the pedal is removed is the pedal supposed to snap the the rear of the assembly? when I'm holding it and play around with it the spring feels like it's pulling the pedal to the back of the assembly. That's how it feels like when it's in the car.
*Update *
Ok, so I removed the Clutch Dampener thingy and redirected the line to go straight to the SC. I Bled the clutch again and still the pedal still goes soft. I took the SC apart and it seems like it's working fine (The Pin pushes out).
I don't know what's wrong here...
Also I came across something... when I took off the SC I tried to push the clutch fork just too see if it wasn't jammed or what not. It seems really hard to push. Is it really supposed to be that hard?
Old 05-17-2007, 08:47 AM   #20
Dream240
Dream240's Avatar
Yes it is. If you can push your throw out bearing pivot fork in with your hand then your pressure plate is crap. HYDRAULIC POWER MAN!!! RRRAAARRRGGGHHH!!!!
As far as the clutch pedal not returning, does the car shift when the clutch pedal is pushed in? Whether or not the pedal is returning?
Can you have someone push the and return the pedal by hand and you watch the slave? watch to see if it is in fact pushing the fork forward. And if so, how far? Is the fork loose on it's pivot? Also is your bleeding and you let the fluid go down to the bottom of the reservior then you're letting air back in the system and going nowhere. What kind of bleeder do you have? A clear air hose really is the only way to go. Let's you see how much air is traveling in the lines.
Old 05-17-2007, 08:55 AM   #21
jrmiller84
jrmiller84's Avatar
jrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond repute
Send a message via AIM to jrmiller84
If it's not returning, you have air in your lines somewhere still, as everyones mentioned. Either there's just air in the lines, a line is busted, or somethings wrong with the sc/mc. After doing my SR swap and replacing my slave cylinder, my pedal wouldn't return either.
Even though the pedal felt right going down and the slave cylinder would engage, it wouldn't return.
Just keep bleeding it and it will return assuming nothing else is wrong.
BitDestroyer.com
jrmiller84 is offline   Reply With Quote
Old 05-17-2007, 09:23 AM   #22
AdamP
AdamP is on a distinguished road
I have a question about the pedal freeplay. What consititutes pedal "freeplay" when adjusting the clutch? Recently I've replaced the pivot ball in the transmission and got my clutch bracket rewelded. Every day or so I adjust the clutch pedal further in (it's sitting about flush in height as the brake pedal).
The reason I ask is that there is a certain point where the shifting from 1-2 and 2-3 is slightly chunky. If I adjust the screw in a little bit, it eliminates this. I don't think the TO bearing is ridden from what I can tell. As for pedal free play I don't really thing I had any floppy feeling at all since there is a return spring on the pedal.
AdamP is offline   Reply With Quote
Old 05-17-2007, 10:50 AM   #23
hsoj_v
hsoj_v's Avatar
No I can't shift into gears when the pedal is all the way on the floor. I'm not using a vaccum bleeder either just flowing fluid though the bleeder nozzles waiting for a clear line until no more air bubbles. Probably I let air in at the time of bleeding... just didn't notice.
Thanks guys... I'll try and bleed the clutch system again.
Old 05-17-2007, 10:56 AM   #24
Dream240
Dream240's Avatar
so you're gravity bleeding it? That's you're problem. I only ever had that work on certain brake systems. You need to have someone manually operate the pedal while you work the bleeder screw. Just use the standard two-man bleeder procedure and you should be set.
Old 05-17-2007, 12:28 PM   #25
hsoj_v
hsoj_v's Avatar
Oh man... i feel stupid. You're right Dream. It was a bleeding issue. Haha Thanks Man! Now my car can finally move after 2 years of it sitting there.
Old 05-17-2007, 01:25 PM   #26
Dream240
Dream240's Avatar
Glad you got it figured out. Damn 2 years? I don't know if I could go 2 months not driving my baby.
Have fun and drive safe!
Old 05-17-2007, 02:03 PM   #27
hsoj_v
hsoj_v's Avatar
OK... well one more small problem. There is pressure in the pedal now but it only comes back halfway. I can start the car but I cannot engage the clutch into gear. I checked to see if the slave cylinder is pushing the rod and it is. Could it be that there is still air in there?
Old 05-17-2007, 02:11 PM   #28
Dream240
Dream240's Avatar
There could still be air in there, sometimes you have to bleed the system out a few times. What you do is bleed it, then start it up, push the clutch a few times to check feel. Then top off fluid and repeat the process. Each time the peal feel should get stronger. If it's returning at all then your system is good. You just have to bleed it out a few times.
Also make sure the fluid stays full while bleeding. And check for leaks in the system after each bleed process.
If this still doesn't work and you've got the SC pushing out all the way on the fork, you got a bad clutch/throw out bearing, that's not allowing the clutch to release. Rarely you will have a broken pivot ball or fork that's not allowing the clutch to work properly. Either way I'd suggest a full clutch system inspection if the bleeding doesn't solve your problems.
GL
Old 05-18-2007, 12:53 PM   #29
hsoj_v
hsoj_v's Avatar
Yey! Got the car moving, Thanks dream. Small problem is that the clutch does go in now it gets into gear but a bit driving around the clutch seems like it starts to get weaker and weaker. so I got to pump it while i'm driving.
Old 05-18-2007, 01:24 PM   #30
Dream240
Dream240's Avatar
After you got done dirving it around was the fluid lower than before? If you're having to pump the pedal then you got a clutch system leak prolly in your M/C. You should have fluid leaking out somewhere.
Is the M/C new? I forget if you said so already.
