Old 08-29-2012, 11:47 AM   #31
EvoVIII808
Here is Mine. Waiting on fitting to arrive.
K-Sport with Wilwood 0.75 (In line)
Check Out My S13 Build
Old 08-29-2012, 06:38 PM   #32
ARPTUNNER67
ARPTUNNER67 is an unknown quantity at this point
this setup is perfect for anyone who dont want to upgrade to z32 brakes just yet, really clean too!
ARPTUNNER67 is offline   Reply With Quote
Old 08-30-2012, 07:25 AM   #33
EvoVIII808
My Ksport came with the crappy master cyl, so i upgraded to the wilwood .75 (3/4 bore) 1 problem I ran into with the Ksport and wilwood is the threads on the adjustment/locker (Ksport) do not match the 5/16-24 threads on the Wilwood (#260-6089)
So you have to either bore it out slightly and re-thread it, or make a new one.
Old 09-25-2012, 10:51 AM   #34
EvoVIII808
*Update* When upgrading to the .75 (3/5 bore) Inline setup. You WILL need a longer handle to operate it. I bent the Ksport handle.
Old 10-13-2012, 08:51 PM   #35
HIGHFIVEBETA
HIGHFIVEBETA's Avatar
HIGHFIVEBETA is an unknown quantity at this point
Ahem* sorry had something stuck in my throat......
Originally Posted by yomisiu View Post
^ its OK. he's from Florida.
HIGHFIVEBETA is offline   Reply With Quote
Old 10-13-2012, 09:37 PM   #36
stephens14sr
stephens14sr is an unknown quantity at this point
how do people like the asd
Full 2014 build progress www.handicapmafia.wordpress.com
stephens14sr is offline   Reply With Quote
Old 10-18-2012, 12:03 AM   #37
OgSilviaSkywalker
OgSilviaSkywalker's Avatar
OgSilviaSkywalker is an unknown quantity at this point
so my friends got a hydro ebrake that isn't locking up. pbm hydro ebrake with a chase bay proportion valve. bled the system couple of times got it to lock up one wheel at one point but bled it again and nothing. we also tried adjusting both the ebrake and the proportioning valve. cant figure it out. lever is also really stiff.
thanks in advance for your input guys
OgSilviaSkywalker is offline   Reply With Quote
Old 10-18-2012, 01:11 AM   #38
EvoVIII808
You may need a longer handle.
Old 10-18-2012, 08:39 AM   #39
Chase Bays
Chase Bays's Avatar
Chase Bays is an unknown quantity at this point
Shoot me some pics of your setup with this!! May be able to help you out a bit. We just did something similar but it went off without a single problem.
[email protected]
Thanks
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE
www.ChaseBays.com | [email protected] | (205)623-2188
Chase Bays is offline   Reply With Quote
Old 10-18-2012, 02:02 PM   #40
TTnickdizzle
TTnickdizzle's Avatar
TTnickdizzle is an unknown quantity at this point
^ how long of a handle did you need to make it work?
TTnickdizzle is offline   Reply With Quote
Old 10-18-2012, 02:13 PM   #41
Chase Bays
Chase Bays's Avatar
We used a CNC 402A in an S13 chassis and it worked perfect with OEM Master.
Old 10-24-2012, 07:58 AM   #42
pattrick02
Banned from the Marketplace
pattrick02 is an unknown quantity at this point
some pretty nice set-ups.
pattrick02 is offline   Reply With Quote
Old 10-24-2012, 11:17 AM   #43
TTnickdizzle
that handle looks relatively short, i Like it... what pads r u running on it? And how much effort do you need to get the rear to lock up? Easier than the stock set up?
Old 10-24-2012, 11:46 AM   #44
Chase Bays
Chase Bays's Avatar
On the 402A the handle really isn't very short at all. Running hawk HP's iirc. Does not require much effort at all to lock up the rear. By far much nicer then stock and much easier.
We are actually about to release the kit as a bolt in for the S chassis with lines and hand brake. Should be pretty soon!!
Old 10-24-2012, 03:14 PM   #45
240dream
240dream's Avatar
240dream is an unknown quantity at this point
who has a good write up on their ebrake install with fitting sizes,what they used/where they spliced into the rear brakes
240dream is offline   Reply With Quote
Old 10-24-2012, 03:30 PM   #46
stephens14sr
PBM has directions on their site. Used it for mine, never had an issue. Works great everytime. (Will wood flow through type MC)
Old 10-24-2012, 05:22 PM   #47
EvoVIII808
i did mine with hardlines from napa.
2x M10 1.0 adaptors
1x 72" 3/16 hardline
1x 51" 3/16 hardline
7/16 -20 thread Big fitting for wilwood
3/8 -24 for the small fitting.
1 adaptor come from the rear brake port into driver side, then connects to 72" line (Way longer then needed) Run across the firewall, down the trans tunnel, and loops back into the rear port on Wilwood.
51" hardline runs down the passenger side trans tunnel, across firewall to passenger side, connects into the 2nd M10 adaptor, Adaptor connected to the stock connector in the engine bay on passenger side.
Old 10-24-2012, 05:49 PM   #48
kunt_masha
kunt_masha's Avatar
kunt_masha is an unknown quantity at this point
heres the setup I had in my daily... CNC hydro
kunt_masha is offline   Reply With Quote
Old 10-25-2012, 06:49 PM   #49
240dream
240dream's Avatar
i think i might get the pbm unit, do you like it?
for install you remove the line off the booster for the rear brakes and attach lines into port the line was removed from. then the rear line you disconnected fromm booster gets run into hydro outlet? is this correect,thats how i interpreted there directions
Old 10-26-2012, 09:49 PM   #50
Supergoji
Supergoji's Avatar
Supergoji is an unknown quantity at this point
Send a message via AIM to Supergoji
nope its for turbo boost
www.NYZC.net
Supergoji is offline   Reply With Quote
Old 10-26-2012, 10:00 PM   #51
stephens14sr
Basically. I love it, feels great and works great. When I bought mine they were sold out of their custom line/install kit so I used hard line and bent it all and put on my own fittings. But get the install kit it'll be easier. I posted a pic on the first page of mine.
Old 11-29-2012, 09:26 AM   #52
_kouki_monster_
_kouki_monster_ is an unknown quantity at this point
i really like the look of the z. i might have to use a little boot like that when i build mine. very clean looking.
_kouki_monster_ is offline   Reply With Quote
Old 11-29-2012, 12:09 PM   #53
h2v7
running inline ever cause any issues?
was thinking of doin this on stock everything 4 lug 89 sohc
Old 11-29-2012, 01:17 PM   #54
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
I run inline, locks great, no issues. Feels a little funky when hitting the brakes at the same time, but you get over that.
di-devol is offline   Reply With Quote
Old 11-29-2012, 02:34 PM   #55
singlecamslam
If i was you^ i would make some sort of quick release for that giant handle, like weld in a nut so you can just unscrew it, cause that looks like a pain to drive around daily with that stick poking out.
singlecamslam is offline   Reply With Quote
Old 11-29-2012, 03:35 PM   #56
di-devol
Thanks for the advice, but the car is now down, and when it's done, no more daily driving for it. It seems a bit tall at first, but leverage was needed.
Old 11-29-2012, 08:40 PM   #57
Pinggg
Pinggg's Avatar
^ I actually like where the handle is place. looks good!
Old 11-29-2012, 09:10 PM   #58
Johnny_K
Johnny_K is an unknown quantity at this point
pic of me using the asd hydro
More info on the car can be found at
http://www.facebook.com/JohnnyKDrift
Johnny_K is offline   Reply With Quote
Old 12-05-2012, 12:18 AM   #59
TunerJohnny
TunerJohnny is an unknown quantity at this point
Originally Posted by JFoxx View Post
Has anyone used the dual cylinder handbrake setup yet? I would like to get some feedback from them....
Overkill. Unnecessary. Awesome to have. I happen to be selling mine. =P
TunerJohnny is offline   Reply With Quote
Old 12-06-2012, 04:25 AM   #60
Elvin Wes
Elvin Wes is an unknown quantity at this point
PBM kit. Love it.
ive always like the look of this.
Bike grip???
Elvin Wes is offline   Reply With Quote
