#5761 | |
![]() Join Date: Nov 2005
Wisefab has some combo of drop and control arm movement to get 56mm My old TDP knuckles had 15mm of hub movement and 55mm of control arm drop for 70mm. Still waiting on my new knuckles... |
#5763 |
This is the roll center, suspension pickup, and steering angle modification t...
100mm roll center correction TDP knuckles. I'm not sure on how they are formatted as far as how much the hub is raised vs the control arm drop. I will measure when I get them.
#5765 |
![]() Join Date: Jan 2007
![]() ![]() Feedback Score: 9 reviews
time for some track testing. The current Australian dollar is good for you guys. The intro price is going to be $199 AUD including our sales tax which is $181AUD excluding our tax = $162USD + delivery.
40mm roll centre correction and a little over 60 degrees of bolt on steering lock. ![]() |
#5766 | |
Is it ready to be shipped to customers?
can you ship it to Muscat, Oman, I guess this is the best option for me for now. Quote:
#5767 | |
Sorry we can't help right now. |
#5768 |
Yeah I know, but it's a lot easier to compare by stating the amount they are changed on the knuckle. We haven't all modeled the front suspension like you :P.
#5769 |
This thread has so much info it's un real! I have a quick question and probably stupid but I currently run tein inner tie rods with the slip on spacer, s14 moog outters, and poly rack bushings in an s13. My issue is that the steering locks up bad at full lock and I can't figure out why. It's super hard to bring the wheel back after it hits full lock. Is my rack over centering? If so how do I fix this? Sorry but I have only recently got into the steering angle stuff. I've read a lot but haven't found an exact answer to this. Thanks!
#5770 |
^sounds like it. There are a number of things that can help fix this like raise the car, reduce caster, move the steering rack forward (modify xmember or use eccentric bushings like what PBM sells), offset tie rod spacers, or try different knuckles.
#5771 | |
#5772 | |
#5774 |
Do these look to be a quality piece? I like the range of adjustment, since I want to run them diagonally, but I do not know anything about bearings or materials and such.
![]() Also, are S-chassis damper shafts generally of a universal diameter? I noticed that most of the upper pillow balls are 18mm ID. I want to try running the Fortune Auto radial top hats. Even if they do not mate up directly, I am sure it should not be too difficult to make them work on most coilovers. Has anyone attempted using them on a non-Fortune coilover yet? |
#5775 | |
Also, Matej, who makes those top hats? I also run my camber plates diagonally and would like some more room for camber/caster. I was thinking about machining my current plates.... |
#5776 | |
I dig how they notched the bearing mount for clearance at the mounting bolt, that's probably good for another degree or so of adjustment, though I'm not sure if that's really going to be useful unless you're increasing the track width. The bearing is a shot in the dark, I'd see if they publish the brand and go from there. If it's some random no name brand, the bearing is probably junk - if it's a well known brand (IE QA1, Aurora, etc) I wouldn't worry about it. The Upper Spring Seat/whatever you call it, might be specific to fortune auto coils - you'd have the take your current coils apart and measure the diameter of the shaft and go from there. If it's smaller, you can probably have a sleeve/spacer machined to make up the difference, but if it's bigger, than you've pretty much got to replace the bearing, which may or may not be reasonable. Edit: I just thought about this some more, and the bearing ID appears to be significantly larger than the strut shaft OD which is why fortune presses that sleeve in there - meaning that you would only need to get a new sleeve made if your strut diameter is different than what it's made for. Odds are you can have any machine shop with a decent lathe knock these out for a couple bucks - on something like this you can pretty much take the existing part in there and say 'I need this, but with a XXmm Diameter hole in it'. To be completely honest, if I were you, I'd take your upper spring seat that's currently on the Coil overs to a Machine shop or someone that knows CAD/Drafting/Engineering Stuff and have them come up with one that works with your coil overs. To be quite honest, it's not a difficult part to design or make, if I had all of the required data in front of me, I could draw it up in ~1hr give or take. |
#5777 |
Thanks for the information. The camber plate is by a company named Dibed from Poland, though they also sell on Ebay. They mostly make parts for BMW drifting.
https://www.facebook.com/pages/Dibed/334916316552003 I looked more into top hat options that rotate independently of the upper pillow ball bearing since it seems that it would be beneficial for ease of steering when the spring/upper bearing is under heavy load, especially when it comes to an activity such as drifting. Apparently people in the 240SX racing community have been into such things: Camber Plate Design - Nissan Road Racing Forums Last edited by Matej; 09-01-2013 at 05:51 PM.. |
#5778 |
![]() Join Date: Aug 2011
I know BC racing gives an option for a top hat with caster and camber independant plates. I dont know if they sell them individually, but you may want to check it.
#5780 |
![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 2 reviews
Here's the early model look on the tension rod I would like to manufacture and sell:
Currently it is not with a double adjuster, but it there is demand it will be introduced. All suggestions and ideas are welcome ![]() For pricetag, I am thinking 150 USD as intro price |
#5781 |
![]() Is there a version that will fit S13 |
#5784 |
![]() Join Date: Jan 2011
First working prototypes are finished.
After just a few miles of normal street driving on these things I can feel a huge difference in the amount of front grip on turn in. First track day testing will be on Sept. 14th. |
#5786 |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
I run FA upper plates on my koni 8610 setup -- just have to play the bushing swap game, at least for konis. The shafts on the konis are 14mm and the ID of the bushing that comes with plates is 12mm so I had to get some bushings from McMaster-Carr to make it work.
#5788 |
![]() Join Date: Jan 2009
Managed to break an LCA at the track this past weekend, debating on what direction to head next. I want a spherical bearing on the subframe side, but I'm hesitant to modify oem arms after this past weekend. I'm thinking about giving this product a try:
![]() My biggest concerns right now are that the ball joint cup isn't welded on at an angle, and he says he's using screw-in ball joints, which I wasn't aware existed in s13 diameter and taper. I'm not too concerned about the lack of a sway bar mount, that can be added later. He also has shims for the tension rod misalignment spacers, so biding isn't an issue while adjusting caster. As far as I know they haven't been tested on a car yet, I'd like to get some feedback from other drivers. Motary's tension rod looks promising, it might convince me to stay with a stock style LCA. |
#5789 |
![]() Join Date: Jan 2005
My take on these arms is they are nothing special. Look at the tubing...it is just ESW tube with a nut welded to it. The welding looks suspect also.
Why not run modded stock control arms...My buddies car had a small run in with the wall and he broke the Battle Version weld in adjuster that I installed. Now that being said the adjuster gave up and saved the cross member just like it was supposed to. Next time I will have a spare set of FLCA's as this ended the day. |
#5790 |
THose look insanely heavy! I remember when I made my single piece arms that about 65% of the original mass was machined off after they had been laser cut. The tension side tubing looks fine, stress is mainly on the rod end body.
| anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
