Old 01-19-2002, 02:45 AM   #1
240booster
240booster is an unknown quantity at this point
I went around town today kinda getting some prices on a tune up and i went to Nissan and asked them if they would put Bosch Plat's on there, and he said that the car would not run right with them cause it was not made for platinum or Bosch plug's. That only NGK would work well. I thought Bosch 4's were the best plugs out there and i didn't think it would matter. Is he right or is he just telling me this in order to sell his product?? THANKS
240booster is offline   Reply With Quote
Old 01-19-2002, 04:00 AM   #2
NiNJA
NiNJA is an unknown quantity at this point
Send a message via AIM to NiNJA
I have recently installed Bosch Platinums in my S14...It runs fine to me.
NiNJA is offline   Reply With Quote
Old 01-19-2002, 04:51 AM   #3
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
remember, planium do not give performance, rather lose performance, they just last a long time.  i use bosch platniumn +4 in my s13 'cause i had it on the camry, and the camry died, i thougth anything b better then stock ngk plugs
240meowth is offline   Reply With Quote
Old 01-19-2002, 08:35 AM   #4
S13 Passion
S13 Passion is an unknown quantity at this point
what about DENSO iridiums?  cuz when i get a tune up sometime in the spring, im thinking about getting them. i heard those ones are the best.
S13 Passion is offline   Reply With Quote
Old 01-19-2002, 09:44 AM   #5
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
Densos are pretty good. I don't think they're worth $15.00 per plug, though. And if you have them, you better be pushing some major power. I had my mechanic (at the Nissan dealership I work at) install some Bosch Platinums on for me. I switched to NGK three months later, just to try them out. I liked the NGKs a lot more, I have to admit. Bosch ones are still pretty good. NGK is great for imports, that's all...
S13Grl is offline   Reply With Quote
Old 01-19-2002, 10:04 AM   #6
lilredstiffy
lilredstiffy's Avatar
lilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to all
Send a message via ICQ to lilredstiffy Send a message via AIM to lilredstiffy
I just tried a set of platinum 4's and then engine wouldn't rev past 4500rpm suddenly. Best to stick with the ngk or whatever your local Nissan dealership sells. Nissan builds very touchy motors.
(Edited by firebone at 10<img src="#/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>5 am on Jan. 19, 2002)
lilredstiffy is offline   Reply With Quote
Old 01-19-2002, 10:06 AM   #7
BEISSEN
BEISSEN is a well-known jackass
Send a message via Yahoo to BEISSEN
I use the +4's platinums in my 97 240 and i have had no problems with them yet,i had the ngks when i first got the car but i took them out to check them and they were completly black so i went and tried to get some more but no one ever has them when i need them.I just did a complete tune up on my car and a complete brake job as well.I changed the front rotors both and all the brakes on the car changed the oil as well along with the oil filter and it runs better.But hey its what ever you realy want to spend on plugs the +4's are like 4.99 each and i dont know how much ngk's are but i will try them next time.
BEISSEN is offline   Reply With Quote
Old 01-19-2002, 10:10 AM   #8
S13Grl
Married to the Mob
S13Grl's Avatar
NGKs are like $1.50 or so a piece. I can get them for cheaper then they'd normally sell (I work at a Nissan dealer.) Let me know if any of you people want any. <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
Old 01-19-2002, 11:12 AM   #9
jupiterl
jupiterl's Avatar
jupiterl is an unknown quantity at this point
Send a message via ICQ to jupiterl
I used Bosch +4 in my 97 ... nothing wrong, however, didn't notice any change to the hp or torque.
jupiterl is offline   Reply With Quote
Old 01-19-2002, 11:17 AM   #10
Nismos14
Nismos14's Avatar
Nismos14 is an unknown quantity at this point
i had bosch regular stock replacement plugs and those were fine then i got a new set to do a tune up did it and it was the same then i went to denso iridiums and bam those were killer i felt a difference with them in.
Nismos14 is offline   Reply With Quote
Old 01-19-2002, 12:19 PM   #11
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
I might be wrong... but I could have sworn I had NGK Plats in my car.... &nbsp;have a bunch of regular NGK plugs lying around tho, and I'll probably switch to those when the turbo is in just so I can do the gapping myself.
AceInHole is offline   Reply With Quote
Old 01-19-2002, 12:24 PM   #12
RoNx777
RoNx777 is an unknown quantity at this point
My '97 had NGK's when i bought it, and i got a tune up in two weeks, i changed to Bosch +4's. Didnt notice any difference.
RoNx777 is offline   Reply With Quote
Old 01-19-2002, 12:48 PM   #13
my240likenoother
my240likenoother is an unknown quantity at this point
Send a message via Yahoo to my240likenoother
i havethe bosh platinum in my car now and i have had the NGK's in before
i feal no difference between the two bolth r good plugs
my240likenoother is offline   Reply With Quote
Old 01-19-2002, 01:45 PM   #14
Arcane
Arcane is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from 240booster on 2:45 am on Jan. 19, 2002
</td></tr></table><span id='postcolor'>
hey booster...just noticed something...why would you pay for a tune up...you can do it yourself...anyways...i have ngk's and my bro has bosch...no difference...
Arcane is offline   Reply With Quote
Old 01-19-2002, 02:16 PM   #15
240booster
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from Arcane on 3:45 pm on Jan. 19, 2002
hey booster...just noticed something...why would you pay for a tune up...you can do it yourself...anyways...i have ngk's and my bro has bosch...no difference...</td></tr></table><span id='postcolor'>
I just knew someone was goin to say that &nbsp; LOL Neway, im thinking about doing that, what all do they do on a tune up?<img src="#/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'> &nbsp; &nbsp;Plus, there r a couple of things that i need done that i don't think i can fix myself.
Old 01-19-2002, 02:54 PM   #16
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
Also, what are the torque ratings etc for the spark plugs?
transient is offline   Reply With Quote
Old 01-19-2002, 03:13 PM   #17
kitoro
kitoro is an unknown quantity at this point
Send a message via ICQ to kitoro
here's some really good information about plugs from a mechanic on another board i'm on:
http://www.albertacars.net/forum/showthread.php?s=&amp;threadid=852
kitoro is offline   Reply With Quote
Old 01-19-2002, 08:05 PM   #18
chickenmanq
chickenmanq is an unknown quantity at this point
#### those stupid dealerships. &nbsp;My dad gets sparkplugs from Nissan for his 91 NX2000. &nbsp;They're NGK, but they're also platinum. &nbsp;Anyone telling you they won't run right with Bosch plugs is wrong. &nbsp;It's true some vehicle don't function well with different plugs. &nbsp;I put Bosch' on my old Mazda, and it didn't do shit. &nbsp;I put them in my Nissan (got tired of ho hum NGK), and there was a performance difference, plus they last longer. &nbsp;Go to autozone, or other store and have them cross reference the NGK number to a Bosch +4
chickenmanq is offline   Reply With Quote
Old 01-19-2002, 09:29 PM   #19
Arcane
booster...tune ups vary between shops...the basics are plugs, (wires if needed) and checking your fluid levels...that's pretty much all it is...
