Old 07-06-2011, 08:36 PM   #1
ramman434
ramman434's Avatar
ramman434 will become famous soon enoughramman434 will become famous soon enoughramman434 will become famous soon enough
S14 carbon fiber trunk issue
So I bought a cf Carbon Creations trunk. After a lot of custom cutting/drilling I've been able to make everything fit on the inside as far as the bolts for lights and whatnot.
My problem is I was driving around town with it on and the trunk popped open twice. The latch itself doesn't seem to be holding. I only have my lock bolted up on one side (there's technically two pieces to the lock - the lock itself, and a metal rod that attaches to a rotating screw that's bolted in just below the actual latch), the rotating screw wasn't actually bolted bc I would have had to cut another hole and I was tired.
I'm wondering if that's the sole reason that my latch isn't holding, because the lock isn't completely bolted. Does anyone have any other ideas? I'll try to post up pics soon of my stock trunk so yall can see the pieces I'm talking about exactly.
Thanks a lot to all who have ideas/answers!
Edited w/cell pics off the stock trunk:
Here is what was bolted up and this is the back of the lock
This is the piece that I didn't have bolted just because there's more cutting. I'm wondering if this piece is bolted if that will solve my problems with the latch. (I'll have to cut into the indo-skeleton of the trunk some more to make it fit
ramman434 is offline   Reply With Quote
Old 07-06-2011, 09:29 PM   #2
AutechKouki
AutechKouki's Avatar
Trader Rating: (43)
AutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura about
Feedback Score: 43 reviews
Finish bolting it on then let us know if you still have the issue.
AutechKouki is offline   Reply With Quote
Old 07-06-2011, 09:50 PM   #3
iLagX
Trader Rating: (40)
iLagX is an unknown quantity at this point
Feedback Score: 40 reviews
Send a message via AIM to iLagX
show some pictures!
PARTING OUT S13/S14 NEED PARTS PM ME!
iLagX is offline   Reply With Quote
Old 07-06-2011, 09:55 PM   #4
Renelovesnike
Renelovesnike's Avatar
Trader Rating: (30)
Renelovesnike is an unknown quantity at this point
Feedback Score: 30 reviews
THIS!!
also i was gonna buy a carbon s14 trunk from a friend but it ended up weighing more than the oe trunk -____- so that plan went out the window
Renelovesnike is offline   Reply With Quote
Old 07-07-2011, 08:42 AM   #5
ramman434
ramman434's Avatar
I won't be able to bolt the trunk back up until this weekend when I'm home. I'm interning in another city during the weekdays.
I'll try to get a pic posted up of the lock mechanism later today. I just don't know how much it will help keep the latch closed since it really doesn't appear to connect to the latch in any way.
Thanks for the replies so far guys
Old 07-07-2011, 08:58 AM   #6
sickstatus
sickstatus's Avatar
sickstatus is an unknown quantity at this point
Send a message via AIM to sickstatus
I had one before. Installed it. Fitment was crap. Didn't lock right. Holes were drilled
Properly. Complained. Showed pics and showed in person. Got to exchange for a new one. Sold it after.
straights are for fast cars, corners are for fast drivers.
sickstatus is offline   Reply With Quote
Old 07-07-2011, 11:30 AM   #7
ramman434
ramman434's Avatar
Fitment is fine, it only sticks up slightly on the corners next to the rear window. My only problem seems to be the latch itself.
Old 07-07-2011, 02:04 PM   #8
Beejis60
Beejis60 is an unknown quantity at this point
that's why you should roll with aerocatch pins.
Beejis60 is offline   Reply With Quote
Old 07-07-2011, 02:44 PM   #9
iamtheyi
iamtheyi's Avatar
iamtheyi is an unknown quantity at this point
I hope you to God you're being a sarcastic prick. If you're talking about the actual trunk latches, then I see where you're going with it.
I agree with everyone else on here. Finish mounting it up then see what happens. Did you check if the hook on the trunk to make sure it has enough length to actually latch? I had one of these CC hoods and the stupid hood hook thing was too short and wouldn't close for shit haha. Scary times.
iamtheyi is offline   Reply With Quote
Old 07-07-2011, 02:48 PM   #10
NissanEnthus
NissanEnthus's Avatar
NissanEnthus is an unknown quantity at this point
You do realize he's talking about a "TRUNK" and not a "HOOD" right?...
OP:
I have never gotten a CF trunk but that rear latch is pretty touchy...You got to make sure it is spot on! I threw an 18 inch tire in my trunk and it barely fit maybe pushing the bottom panel a couple milimeters forward and even though it looked like it was going to close the latch would not lock...
NissanEnthus is offline   Reply With Quote
Old 07-07-2011, 09:11 PM   #11
ramman434
ramman434's Avatar
Yes, this is a TRUNK. I'll def. look to see if the latch isn't catching. I'm using the stock latch so hopefully it is.
Thanks to everyone for the replies so far. I'm going to try to refit it tomorrow night when I get home.
I already have installed my HOOD w/aerocatch hood latches, thank you. I bought the cf edition ones and they look real good w/the hood. I'll prolly have pics of that posted up in the Kouki thread this weekend.
Old 07-08-2011, 03:29 AM   #12
anton1o
anton1o's Avatar
anton1o is an unknown quantity at this point
Send a message via MSN to anton1o
Ive also got a CF "TRUNK" / "boot" and i had a few issues also, The latching just doesnt work as its meant to, but mine actually stays closed when it is closed but when closing it have to make sure you press completely down so it actually grabs.
If you want me to take photos of my setup i can, as it may help
anton1o is offline   Reply With Quote
Old 07-08-2011, 08:35 AM   #13
ramman434
ramman434's Avatar
Yes, please do!
When I closed it last weekend I had to shut it pretty hard in order to make it close, but I'm wondering if I may need to drill the holes for the latch just a bit lower.
As someone mentioned above, it may be that my latch isn't reaching completely down to lock, so that's definitely one thing that I'll be measuring tonight when I'm tinkering with it.
Old 07-08-2011, 10:54 AM   #14
NissanEnthus
I saw your post in the Kouki thread really interested in pics of that CF hood...I have been thinking of getting one myself but always wondered about their fitament.
Old 07-08-2011, 01:30 PM   #15
ramman434
ramman434's Avatar
I'll try to get some up for you tonight ^^. I'm really happy w/the way it came out. I was stressing big time w/having to cut holes in my new hood lol
Old 07-08-2011, 01:40 PM   #16
whitenoise
whitenoise's Avatar
whitenoise is an unknown quantity at this point
Send a message via AIM to whitenoise
OP , if u still have the problem with the latch opening by itself, u can add aerocatches for extra latching . Just make a flatbar for the pins and ur set . Also u can get a sprin from a factory wingless trunk ( non SE ) so the springs r less stiff .
http://TM-SPL.COM
whitenoise is offline   Reply With Quote
Old 07-08-2011, 07:47 PM   #17
ramman434
ramman434's Avatar
Whitenoise, I was thinking about that as a last resort by adding more aerocatches and I was wondering about if there was anyway to reduce the spring tension. Is there any other way besides swapping out the springs? Also, why do the base's springs have less tension?
For anyone wanting to see what my hood looks like installed, I've finally posted some pics in the Kouki thread:
#/f/chat/301737-kouk...hread-184.html
And now I'm headed out to the garage to mess w/the trunk
Old 07-08-2011, 08:44 PM   #18
whitenoise
whitenoise's Avatar
its because base model without wing doesnt need it and if they put the strong spring without the weight of the wing, the trunk will be popping off like a rocket lol. or maybe u can adjust the height of the lower latch ( trunk side ) so the CF trunk loop will hit the lower latch sooner and have room for the loop to grab on .
http://TM-SPL.COM
Old 07-08-2011, 11:48 PM   #19
ramman434
ramman434's Avatar
Well I figured out the problem. The pre-drilled holes for the latch are too low so when bolted in, the latch sits about 1 cm too low, therefore it's not able to connect up. I swear Carbon Creations may have been retarded when it came to the endo-skeleton of the trunk, I've had to custom fit parts and cut out huge chunks in order to make things fit.
I'm going to have to re-drill the holes in the morning, but I've gotta find some locking nuts to hold the new, longer bolts that I'm going to fit through the latch onto the trunk. Otherwise they'll just kinda be hanging out. I'm gonna cross my fingers that this will work...
Old 07-09-2011, 02:12 AM   #20
iamtheyi
iamtheyi's Avatar
Same problem I had with there hood :P. that's why I returned it. Read my previous post. They made the hook for the hood to short so it wouldn't *click down.
Old 07-09-2011, 10:30 AM   #21
ramman434
ramman434's Avatar
Well I'm not exactly w/in returning distance lol. That's halfway across the country since I live in Nashville. It's a simple redrilling of holes, so if I get bored later today I'll just go do that and fit the damn thing
Old 07-09-2011, 10:33 AM   #22
bookoo
bookoo's Avatar
bookoo is an unknown quantity at this point
You never had your car fellow tennspeeder
bookoo is offline   Reply With Quote
Old 07-09-2011, 11:44 AM   #23
iamtheyi
iamtheyi's Avatar
lol very true. Returning is out of the question for you.
Old 07-09-2011, 01:56 PM   #24
Beejis60
No sarcasm, yes I know he's talkiing about the trunk. Run aerocatch pins. Saves weight and elimnates fitment isssues. You guys have never seen real race cars do this?
Old 07-09-2011, 02:24 PM   #25
iamtheyi
iamtheyi's Avatar
Those are just trunk latches not aerocatch pins.... if you knew how an aerocatch worked, i don't see how you could make it work ona trunk. Where would you mount it?
Old 07-09-2011, 03:19 PM   #26
Beejis60
If I know how aerocatch latches worked....
amusing. Insulting me will not help you get your questions answered, fyi.
With that being said, I know I don't have many posts here but it doesn't mean I don't know shit, so IDK why it seems like you're trying to turn this into a pissing match.
A lot of guys I know run aerocatches for both the hood and trunk; some even run them for their bumpers as well.
To make it work for a trunk, you can either run two or four latches, though in 'real life' I've only seen people run four latches, I have, however, seen people run two latches in pictures. I have also seen people run four latches on the hood; myself being one of those people running four on the hood of my last car.
Old 07-09-2011, 04:33 PM   #27
iamtheyi
iamtheyi's Avatar
I apologize and I step down from my high horse. It's hot right now and I'm agitated lol. My bad.But yeah, I don't understand where you'd mount them. to work, they need to be pushed INTO from top down like the hood. So would you drill them into the top of the trunk? and mount the pins where the taillights go?
Old 07-09-2011, 07:07 PM   #28
ramman434
ramman434's Avatar
I have 2 aerocatches on my hood, but as for the trunk, I'm sure I'd have to make a bracket or something, but that's beyond my expertise, nor would I know exactly where to mount them.
Plus I use my trunk a lot, so I don't want to have to constantly be going and popping open the aerocatches before opening the trunk
Old 07-09-2011, 11:07 PM   #29
Beejis60
Go on either side of the mechanical latch towards the tail lights if you want for lower mounting point. And here's an S14 with two aerocatch latches in place of the hinges.
Old 07-11-2011, 09:00 PM   #30
ramman434
ramman434's Avatar
Yeah I ended up not having the time this weekend to finish the trunk....
I would be very interested to see the inside of that guy's trunk and how he's bolted up the pins and everything^^
