Opinions on engine components
Looking at buying an s15 dont know fuck all about SRs but just want an idea of the strength/reliability of this engine. Pretty much just want to know if the parts used are capable of handling the power that he claims it makes.
thanks in advance Engine: Extra oil galleries drilled in crank Custom E&H main bolts Custom main & big end bearings JE forged pistons oversize Brian Crower H beam rods SR20VE high flow oil pump & larger oil drive collar Head: 1mm oversize ferrera valves (3 angle grind valve seat) Bronze racing guides Full port and polish Supertech double valve springs with titanium retainers Full solid lifter setup HKS 264in & 272ex cams (still has VVT) HKS rocker arm stoppers HKS cam pulley Brand new cam chain & tensioner Cosworth H11 head studs 3 layer head gasket Fuel: Injector dynamics ID1000 injectors Sard fuel pressure regulator Twin 500hp in take fuel pumps Aftermarket fuel rail Intake: Greddy genuine manifold 70mm Naprec throttle bottle 100mm intercooler GFB 50mm BOV Stainless intercooler piping Turbo: Garrett GT3582R turbo Sinco custom E&H design tuned manifold Tial 44mm wastegate plumbed in 3inch from turbo to fire wall, 3.5” through 2x adrenalin mufflers Computer: Link G4 storm computer In-cab variable boost control Power: 305kw atw on low boost (15psi) 410kw atw on high boost (24psi) If you put it on E85, and put spitfire coils in, it will pump an additional 30-40kw |
![]() Join Date: Jul 2005
You buy the car assuming the engine is trash. Dont pay a penny extra for the engine parts.
that way, when you find out that its bad, or missing parts, you paid for what you got. |
