#151 |
![]() Join Date: Mar 2008
#152 |
Believe me, i've tried and i tried and i tried, haha. That's why i said that you'll need a shorter handbrake cable that goes to the left rear.
Photo is from a few years ago. All the stickers are gone. |
#153 |
My ebrakes work fine with the r33 cables on my s14. I believe one side is longer than the other so maybe you had them flipped? I dunno, something doesnt sound right with your setup..
#154 | |
There might be but this isn't any sort of special powder. I've done two lapping days and competed in Global Time Attack, I also daily drive the car. No signs of fading or fatigue. |
#155 |
I picked up some Z32 NA hub & ebrake assemblies in an effort to build up parts for the full Z32 swap onto my S14... what should I look for on the brake/hub to convince myself they're in good shape?
Visually they're pretty clean, much less surface rust than I usually see on the pics in swaps. Spins smoothly enough by hand, takes maybe as much force as turning a door handle. Anything else I should look for? Seems like the main test is wheel-wiggling once it's all mounted up, but I wanted to check what I could before going that far. |
#158 |
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
Z32 rears with modified (or trimmed) dust plates.
Had a set on an S14. They're massive. Would have kept them, but they really limited my wheel options. Pretty much mandatory to run 18's up front. 17x9 +0 TE's. |
#159 |
Niceeeee. Yeah I run Z1 two piece rotors on my z34 and love them. Plus I'd like to keep the brake feel the same on both cars. I'm assuming I can use the z32 ebrake setup with the Z34 rear caliper.. then I can use the two piece front and rear.
#160 | ||
..unless you're talking about running some kind of custom two piece rear rotor? |
#162 |
I could email Jon at Z1 and ask him or measure the inside of my 370z rear rotor and compare. I'd hope they're the same. Otherwise I don't think it'd be hard to find a set off a 370 since there's probably not much of a market for them so junkyard find should be easy
#164 |
I didn't want to make a new thread so I thought I would ask here.
Is it mandatory to run 18's if Evo X calipers are installed in the front? Or would 17's clear and be dependent of the design of the wheel/rims? I recall my Work Equips barely clearing Z32 calipers on my first Kouki....... |
#165 | |
![]() Join Date: Nov 2007
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 15 reviews
- このノイズをファック -
#166 | |
Anyone want a set of Evo X calipers? LOL. |
#167 | |
![]() Join Date: Sep 2005
Trader Rating: (48)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 48 reviews
Evo x front with oem 350mm rotor Sti rear with z32 rotor and z32 drum ebrake So to answer the question simply, yes 17's fit over Evo x fronts. BUT ONLY CERTIAN WHEELS... ALOT has to do with the shape of the barrel not so much offset(I'm not going to dive into that because a lot changes as the width/offset changes). So the main focus is shape of barrel and spoke design. Wheels THAT CLEAR te37 no spacer needed Advan rg2 no spacer needed Rays ms01 25mm spacer needed and some grinding of the caliper is required(very small amount) Panasport c5c2 22-25mm spacer I'm sure there are others out there but this is a list of what I know works. Now a list of what DOES NOT CLEAR Work vs-xx Regamasters Volk cen28 Prodrive gc 06 Sprint heart cp035(close but no luck) Rpf1's Again there are a lot more, but I only have so many sets to try. Wheels THAT MAY CLEAR Rays lmgt4 Volk se37 Meisters s1 Professor's I hope this answers a few questions. I am not going to post any other pics as I am not going to spoil my build thread that's soon to be posted.
![]() Do you suffer from vaginal dryness... |
#171 | |
![]() Join Date: Dec 2013
![]() ![]() ![]() ![]() Feedback Score: 4 reviews
But will they stop as well as greddy or hks brakes? These brakes are made by some lombard hillbillies in some Italian backwater, they are far inferior to their jdm counterparts. |
#173 | |
![]() Join Date: Sep 2009
![]() Guess I'll be getting some works Cr kai too |
#174 |
Front:
Wilwood Forged Superlites 6Pot a little more piston area than R34GTR. Willwood Floating Rotor 12.76" with ARP bolt and 304 Wire. Wilwood BP-20 Pads Willwood Lines Rear: Z32 Caliper full RB Willwod Slotted Disc EBC red Stuff Pads Custom Stainless Lines I put the Z32 or 1 11/16 Brake pump, and i dont know yet if the oem booster go fine with this setup, the Z32 dosnt fit for the turbo. ![]() ![]() |
#179 | |
I'm trying to get in contact with street faction They have a rear dual caliper set up it's a cts-v rear caliper and a 300zx rear caliper and i can't find anyone on here that has done the swap but I'm going to call them tommorow to see if they can make me a bracket . ![]() http://streetfaction.myshopify.com/p...nt=12146287809 Sent from my iPhone using Tapatalk |
#180 | |
Have you had this set up out on a track yet? or anyone else with the 6 piston set up. I am worried the balance would be off a fair bit with only stock z32 rears. what would be a good rear caliper to match? Also where did you purchase the calipers from. Only place I have found them: http://www.fastbrakes.com/product_p/...0sx%2013-6.htm Thanks |
