quick question...i tried searching for s13's with this kind of fitment...and this is my question and what i got:
ill be getting some 17x9 +10 for my s13 on january... and with 235/40/17 all around (front and rear) will it clear my fenders? im pretty sure ill need rolling in the rear but do i need a pull? or is it just better to get rear overfenders? how about the front, will it fit? or is it better to go 225/45/17 car is: 20mm wider on the front, cusco comp-s coilovers, i know for a fact the brakes (q45) will clear |
That will fit perfect in the front with 235's and almost no camber. On the rear just run some negative camber, or if you don't want alot of negative camber just pull it a little.
![]() Join Date: Nov 2004
here is what i was told a while back when i bought my work wheels and thought it was stupid but it makes lots of sense...... make your car fit your wheels!! in other words, order those wheels and then once you get tires installed youll know what you need to do to make them fit.
jsut to add to my post, 17x9 +10 should clear z's and coil overs so you just have to play with camber and rolling/pulling fenders and also experimenting with tire sizes
