Old 07-29-2009, 07:23 PM   #1
bl3ujay07
bl3ujay07's Avatar
bl3ujay07 is an unknown quantity at this point
SR "Leaking WATER(???) from front main seal?? NO START!! HELP" pt.2
Ok, so continuing the problem, i changed all new steel turbo lines to band new steel turbo lines AGAIN because when started, it looks like water/coolant is running from there. Changed the turbo coolant hose that connects to the back of block. Drove and found it it was not it. Lost a bunch of water becase it was misting and jetting out like crazy from a leaking water hose.
Next day, i went and changed out the heater hose. Started up fine and everything was good. test drove it and heard a weird sound and a little chatter from under the hood driving 3 miles back from test drive and lost a hole bunch of power. came to a stop at a light, car died, and couldnt get it started back up. pushed it all the way back home, like almost a mile away. Push started the car and i knew my turbo blew. Let the car sit for like 4 hours, took off intake pipe, and found some water droplets inside the line that connects to valve cover. Thought it got in somehow when i was adding water to radiator and fan blowing it all over the place.
I then checked radiator, low on water/coolant. Drained some, and there was no water/oil mixture. Checked the dip stick several times and looks like no mixture either. Removed spark plug, and spark plugs are wet and little bit of water inside the cylinders, from what i can see.
Now, i thought blown head gasket and blown turbo, but my brother said it could be from blown turbo. leaking or blown seals blowing water through turbo into the intake valves into cylinder. It sounds correct too, but i dont know. What do you guys think???
btw...the guy i bought it from said s14 t28, but it does not have a garrett serial number so im thinking it was a fake garrett with garrett turbo housing.
bl3ujay07 is offline   Reply With Quote
Old 07-29-2009, 07:56 PM   #2
Sileighty_85
Sileighty_85's Avatar
Your brother is an idiot dont listen to anything else he says
water CANNOT leak into the charge system throught the turbo
water only runs threw a passage of the turbo to cool it, there is no seal for the water to leak into the intake system
you probably didnt bleed the air from the system causing it to overheat and blowing the head gasket.
do a compression test
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-29-2009, 07:59 PM   #3
bl3ujay07
bl3ujay07's Avatar
^^^Thats what i thought too, but, i did bleed the system, everytime i added new water/coolant.
So most likely its a blown hg right? No other way for coolant into the cylinders right?
Old 07-29-2009, 08:06 PM   #4
Sileighty_85
right, compression and leak down test will give you your answer
the only way you will get a chocolate milk looking oil is if the engine was running for a while with a blown headgasket.
My KA had a blown H/G oil looked fine, till i replaced the HG and ran it for a few minutes.
後輪駆動車1番
1986 SR86 - 200ish
Old 07-29-2009, 09:11 PM   #5
bl3ujay07
bl3ujay07's Avatar
any other input?
Old 07-29-2009, 09:29 PM   #6
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
Do a compession test and leak down first
built ka-t
importdude is offline   Reply With Quote
