Old 09-01-2014, 03:07 PM   #1
Dieu
Dieu is an unknown quantity at this point
Please help identify leak
Hello..I am new on the forum and new to the 240SX scene. I got my s13 half year ago and didn't really do much to it. 2 days ago I noticed that the floor was filled with a bunch of fluid. Seems like the fluid is coming from around the front driver side wheel and I saw the fluid dripping from next to the tie rod area. Can someone please identify where does the leak come from? Thank!!
File Type: gif 10654013_844584112248816_1435733949_n.gif (250.7 KB, 36 views)
File Type: gif 10660956_844584105582150_1758571160_n.gif (266.1 KB, 35 views)
File Type: gif 10643224_844584108915483_2024586409_n.gif (251.3 KB, 34 views)
Dieu is offline   Reply With Quote
Old 09-01-2014, 04:05 PM   #2
Primo's Silvia
Primo's Silvia's Avatar
Primo's Silvia is an unknown quantity at this point
Are any of the fluids low?
-color of fluid?
It seems to b powersterring fluid?
Primo's Silvia is offline   Reply With Quote
Old 09-04-2014, 09:33 PM   #3
Kingtal0n
Kingtal0n's Avatar
THAT PLASTIC PANEL hanging down is just a protective plastic you can remove easily, its mostly 10mm bolts. You should take that plastic panel off and inspect the engine itself. there is almost always an oil leak on a KA24X engine at either the front main seal, or the valvecover. And other places of course, but those are common to check first.
If the front of the engine looks all oil and filthy, but its all down by the crankshaft pulley, its probably the front main.
If all the oil seems to be coming from near the top of the engine, then its probably the valvecover, or something else up there...
https://tinyurl.com/turbo240
Old 09-05-2014, 01:43 AM   #4
badass8
badass8 is an unknown quantity at this point
If its a dual cam it could most likely be the power steering fluid as stated above. Considering the power steering reservoir and pump are on the driver side. Just simply check to see how much fluid is in the reservoir and go from there.
Try to take pictures during the day as well.
Lexus V8 Into S13 Build
badass8 is offline   Reply With Quote
Old 09-05-2014, 06:19 AM   #5
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
Because of the depth of color on your frame pieces, It's most likely oil. Possibly power steering.
Coolant just doesn't look like that to me. If you really can't find the leak and need help, go to the auto parts store and get UV dye.
You have to consider also the off chance that what you're seeing is water from the roads getting trapped in a dirty plastic panel... That panel could have had old oil and grease drippings in it mixed with dirt and water would make the sludge you're seeing.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 09-05-2014, 11:35 AM   #6
Dieu
I checked it today and I found out that it is leaking from the power steering rack seals..do i need to replace the whole steering rack or just the seals?
Old 09-05-2014, 11:37 AM   #7
Dieu
I checked it today and I found out that it is leaking ps fluid from the power steering rack seals do i need to replace the whole steering rack or just the seals?
