sup everyone, wanted to get some opinions of my fitment and what i encountered.
s13 fastback (stock fenders) 17x9+20 + 235/40/17 Federals (all around) Tein HE's Front - Ichiba hubs Rear - S14 SE hubs The wheel originally mounted barely without a spacer when it had no tire, after mounting the tire i had to use a 5mm spacer (see clearance bellow). It doesnt rub but it looks rather close. I also did a 5mm spacer in the rear. Rolled front and rear fenders, relocated the harness, banged inside of the fender well, no rubbing.. concerened about possible future rubbing issues when the tire starts to flex at higher speeds. Car needs an alignment, since after the ES master bushing kit install everything was thrown off.. front camber is all the way negative right now.. hopefully with proper alignment i can pull back on camber a bit and still clear the fenders.. No outside pics yet as i'm still trying to decide if to raise the rear or drop the front some more? I wouldnt mind going lower but circuit sport midpipe is hanging pretty damn close to the floor. From what i've researched many got away without spacers on HE's, for me it didnt work, yet other say that its almost a must.. not sure if it matters due to tire brand but in my case for sure it will not clear without a spacer. Any advice is greatly appreciated. Many tks in advance! |
trust me when i say that'll fuck up your coils, it'll rub and rub bad, the tires will rub the coils and it'll spin and it'll rub, rub, rub
get some spacers, i'd post up pics of my 17X9 +27, 235/40/17, but i'm too lazy, it's on the Group Buy:MB motoring wheel section... i need at least 5mm on my jics to clear without worries, but i used 10mm... rears are not a problem of course |
![]() Join Date: Jun 2004
Federals have a huge frame and usually just look goofy..
[email protected] |
im at 17x9+15 now with that 5 mm spacer.. like i mentioned i dont see anything rubbing, there is little space left but not much, my only concern is for hard cornerning as the tire is bound to flex a little.. that little can hit that coil.. a quick fix would be wider fenders that i just dont dig, i know it will solve the prob right away. Perhaps try a different brand tire later?
I'll get some pics up tomorrow of outside hopefully maybe drop the front some rear and see where it will start to hit the fender and check exhaust clearance as well.. |
just by looking at your pics above, it really seems like the tire will rub on the coil, the rims won't ever touch, but the tires look like it positively would... after a while, if you notice rub marks on your springs, you'll know that you need couple more mm in spacers or run thinner tires
rears are not a problem with that size, no spacers needed |
many tks for advice, i will most definitely keep an eye on the coils and see what happens. As for rear only reason why i went with a spacer is to match the front and keep the track width the same as stock of course with bigger wheel/tire combination. Back is no probs at all.. plus i like the rear ride height.. :-) need oem sideskirts badly now.. :-)
this is a pretty interesting thread. I just recieved my work XD9's in 17X8.5 front and 17X 9.5.... Rear fenders have slight roll. fronts rolled...Put new cusco's zero's in this afternoon and the wheels are getting mounted with 225's in the front and 235/45's in the rear.......any guesses on if i'll be rubbin on anything.
#13 | |
![]() Join Date: Jun 2003
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Yo Ismar,
Glad you finally got some tires put on, but I'm surprised how little clearance you ended up with... it may be just that HE's have the least clearance, as both my coils, with a bigger tire, were fine w/ a +20. I'd say just get a bigger spacer and run a little bit more camber, maybe push the fender out a bit more, and you'll be ok on a stock fender.
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till. -Emerson |
#18 | |
listen to aaron... i learned everything i know from him and lindsay... funny thing is that i asked him this question 3 years ago... you can also adjust your camber from the knuckle spindle on your tein he hybrid_eg... its the top bolt... the hole on the strut mount is eccentric.... or you can get extended studs and run 10mm... if not just add another 3mm on top of your 5mm once you get the extended studs... how do you say that aaron??? oh yes... done and done....
http://www.thenismoshop.com |
#19 |
Trader Rating: (73)
Yeah, sounds like you need to get either:
A) Extended studs and a spacer B) Different wheels C) Different Coilovers I do remember hearing something about Teins have BAD wheel clearance. But I'm not sure who I heard it from so the word may be less credible.
#20 | |
![]() Join Date: Sep 2005
If your scared of your fresh pant being cracked oh well. your car is a garage queen anyways lol but to the main topic. fuck the federals. Those tires are so think as it is. If you compare a 215/40 to a falken its insane. But you are going to have to roll your fenders and run spacers. why not run a 7-10mm spacer with more camber??? |
#21 |
don,aaron,ray and others many tks for advice guys! i know its an old topic and i appologize for covering it once more. I'll try adjusting camber from knuckle and see how far this gets me. I still have plenty of room tire/fender clearance as i probably slightly pulled the fender while rolling. I already have extra extended studs for the front in case i need to run a little bigger spacer.. maybe either 7 or 10mm worst case scenario.. as for wheels no way i'm changing them :-) its either run these or run stock SE's :-) I'll look into different coils as last option but as of right now it looks like it will all work out fine. I will update this thread some more with new pics as soon as i get a chance.
Tks again all! |
#23 |
17x9 +20 is not that bad... its still better than some 17x9 +35 taiwanese crap....
#26 | |
17X9.5 and +17 in the rear with 17X8.5 +22 in the front..... it looks gross with no roll. GOD...doing a good roll this weekend.....
#29 |
to those that are running similar size offsets like me what coilovers are you running? i knew HE's wouldnt have a good clearance period, but what other models would have say optimal wheel to coilover clearance?
tonight i will adjust the knuckle and see how far this gets me, and if that doesnt help i'll try 8mm first then like aaron said 10mm up front will clear like there is no tomorrow :-) |
