#2971 |
Thanx guys. I just looked up those skyline knuckles. The first set I found was from an R32. They did have some weird HICAS link mount, but they are aluminum, and they do have the same damper mount location as the S14! Sweet
I have a new set of Ohlins that do not have removeable bottoms. I'd have to pull the dampers apart, hack the bottom off and fab up my own bottom bracket (or just mod those pretty MAX parts) and weld them on. Skyline parts may be the ticket.
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
#2972 |
On the off chance anyone else is in the same boat I am, a little further internet sleuthing found that the R33s are iron just like the s14 rear knuckle, and the R34 use the same style damper mount as the Z32, but are 10mm wider at the mount. And supposedly SPL can get you a good bushing to ditch that weird HICAS/toe mount on the R32 knuckle.
#2973 | |
![]() Join Date: Jan 2005
#2974 |
A little OT, but curious on what the general consensus is on rotating camber plates for caster adjustment, and adjusting tension arm to stock length to reduce bind and aid in clearance at front inner guard?
I understand that top strut bracket hole would need to be slotted a bit more to get decent neg camber again. I've heard that possible downsides to this are adversely affecting KPI and adding bumpsteer? If it matters I'm running heyman knuckles in a low s14 on BC coils. |
#2975 |
![]() Join Date: Nov 2005
You can do it, but you're probably not going to have enough negative camber if you can't extend your lower control arms.
#2977 |
That can only go so far, and starts affecting other things too. The best thing you can do is experiment.
#2978 |
#2980 |
![]() Join Date: Aug 2006
Trader Rating: (-1)
![]() ![]() Feedback Score: -1 reviews
The rotary 86 by Darren McNamara has a special steering setup (gotta see it to explain it) that speedhunters doesnt have enough photos to make out how easy it could work- if one was able to fab one up. Anyone with more info? Thanks
#2982 |
![]() Join Date: Oct 2006
On my to-do list of upgrades are larger sway bars, I found that Sikky makes a 32mm front sway bar, it also allows you to run the crazy modified knuckles without hitting the sway bar. Scroll to the very last page of the install instructions for pictures of how the sway bar is now parallel to the tension rod. http://www.sikky.com/images/pdf/1285...on%20Guide.pdf
I was wondering if anyone has this installed on their car and can confirm that it will work with a Nismo power brace? If no one can confirm I will just call up Sikky and ask, but figured someone on here has this sway bar and could give some input. |
#2984 |
I'd lean towards the Sikky just because it's been designed with two things in mind:
1) Excessive Steering Angle. 2) Clearing non-KA/SR Oil pans. I've got a 1J in my car and there's no way to run a normal S-Chassis Sway Bar without hitting the Oil Pan. |
#2986 | |
![]() Join Date: Jul 2004
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
The old ones were cause they were solid. Now I believe the 32mm are hollows. (Something to take the place that Largus left open)
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got ![]() |
#2988 |
#2990 |
#2991 |
Just got off the phone with Sikky, here's what I got. Their's is hollow, made of steel and will clear the Nismo power brace. I can see an argument for materials where the Tanable would be stronger since it is made of chromemoly.
#2993 |
It's not about how light or hollow
it's about stiffness ![]() most of the people I know that track their cars swear by Progress sway bars so that's what I'll be trying |
#2994 |
![]() Join Date: Apr 2004
I track my car and want as light of a swaybar as possible. Why bother trying to reduce weight on your car to hang a huge heavy sway bar out front that offers no extra stiffness over a hollow bar of just slightly larger outer diameter?
#2995 |
![]() Join Date: Dec 2004
Trader Rating: (58)
I'm almost to the point of selling my Whitelines and going with Hollow ones myself. Can't say I had any issue, but they are are pretty heavy!
#2996 |
![]() Join Date: Nov 2009
This and if you haven't held a tanabe swaybar you wouldn't know what I'm talking about. It's literally feather weight and if i recall honestly felt lighter than the stock garbage... so yeah...
#2997 |
![]() Join Date: Nov 2004
You will gain more from lightening unsprung weight on your car.
What wheels are you running? Light wheels along with aluminum bodied coilovers would help quite a bit.
#2998 | |
You get the most out of making your car as light as possible everywhere.
#2999 |
Ummmm, isn't 32mm freakin' HUGE? What rear bar are you going to pair that with so you don't understeer? Tanabe's are 30.4 front and 27.5 rear.
I guess you could change your spring rates up to accommodate the differing bars.
Tags |
anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
