![]() Join Date: Jul 2002
![]() ![]() Feedback Score: 3 reviews
DMax hood fitment
As is seeming to be quite common I have an interferenace problem with the front of my valve cover and the hood when running the nismo engine mounts...does anyone not have this issue? If so what mounts are you using?
I never knew you could do that with an eggplant |
Banned from the Marketplace
![]() Join Date: May 2006
I'm assuming you're running a KA and the nismo mounts lift up the KA an inch or so and the DMax hood was probably designed with a SR in mind. My YF hood has a similar probelm, but barely rubs. Just get some lower motor mounts and you'll be fine.
![]() Join Date: May 2002
it rubs SLIGHTLY
can cut out underneath or raise the rear 2 of my friends have aDMAX on a s13 silvia face and a flip up s13 (180sx) nothing u cant make work its easy |
#4 | |
Like a number of other people on the forums I refilled my old motor and transmission mounts with construction grade polyurethane adhesive and called it a day for mounts. I may end up venture into making custom solid mounts out of aluminum or some other metal.
Do need the Factory Service Manual? Click here. |
I lowered my engine slightly by grinding the slot on the frame [both sides] where the engine mount bolts on,unbolt the engine mounts to the frame raise the engine , use a die grinder and a carbide bit and lengthen the slots down the frame then work the engine down a bit lower
Give it a try might help! |
Dousan,
any idea how much interference we are talking? I can get a 1/4" from chainging to URAS mounts is that enough or not? Hustler Its an SR
![]() Join Date: Apr 2005
the mounts sit pretty much in the middle of those slots.... i can see that only effective in lowering one side of the motor while raising the other. unless of course youre on stock (blown) mounts that flex downwards LOL |
anyone have any specs on excessive's solid aluminum mounts?
Who stocks the kazama mounts?
#10 | |
More Japan |
![]() Join Date: Sep 2006
![]() ![]() Feedback Score: 10 reviews
i have cusco mount, s14sr in 180sx and dmax carbon fiber hood. it doesnt hit anything. but then again i got this hood 3 years ago fefore anyone, and the underside of my hood is different than the new dmax hoods now. maybe thats why mine doesnt hit.
How is your underside different...I thought they were all the same....
