Old 12-11-2010, 12:15 PM   #1
ItaliaBrat
ItaliaBrat is an unknown quantity at this point
Alignment Done, and still pulling to the left
Like the title says I was just up at andrews afb at the firestone they have on base and got an alignment. I got on the freeway and it was still pulling left! I have a chart here and some stats that they printed out for me, I am no good with suspension so help would be great, also I have brand new tires on the front mounted on some old school Porsche rims and feeling vibrations on the steering wheel when I hit about 55.
Here are the numbers they printed for me:
Left Front: Right Front:
Camber- o.o deg. (Green) -1.3 deg. (Green)
Caster- 2.8 deg. (Highlighted red) 6.7 deg. (Green)
Toe- 0.75 deg. (Red) 0.60 (red)
Now with all of that everything that is red is BACK to green EXCEPT the front left caster! Now would that pull the car left? Looks like the rest of the numbers when it was tweeked are pretty close for front and back, left and right, BUT the caster. The number (2.8) for the caster stayed the same. So I don't know why they couldn't fix that...?
Here is what they recommended when they did the courtesy check:
2 tag lights
RF Inner & outer tire rods
Both bel low boots
2 rear + <<<<<(I can't read his handwriting)
Would the inner and outer tire rods for the right needing to be replaced push the car left??
Thanks for reading, any information would be baller!
ItaliaBrat is offline   Reply With Quote
Old 12-11-2010, 12:26 PM   #2
badbob2121
badbob2121's Avatar
badbob2121 is an unknown quantity at this point
i would definatly get new tie rods, and never ever get an allignment on base....ever
asked around the local shops for someone they recomend if you dont know anywhere else to go
FOLLOW ME ON INSTAGRAM = BOBBY_LS13
badbob2121 is offline   Reply With Quote
Old 12-11-2010, 12:33 PM   #3
S14DB
AFC #1
S14DB's Avatar
T/C rods control the caster. Sounds like you don't have adjustable ones. The car was probably hit at one time on the left side bending the Bracket, T/C Rod and/or lower control arm.
The factory arms should only sag 0.75* in ether direction from 6.75*. 2.8* is a MAJOR deviation from that.
Old 12-11-2010, 01:32 PM   #4
ItaliaBrat
Bob you at Andrews?
Old 12-11-2010, 01:38 PM   #5
240sxrb25
240sxrb25 is an unknown quantity at this point
caster caster caster....i do alignments all the time i dont care if the caster is in the red so much but they have to be close to each other. if you have more caster the wheels will want to strighten out of a turn on their own.
you have 2 diff caster numbers that is why. your caster effects side to side pulling more than anyother angle. your car has most likely been curbed pretty good on that side before.
240sxrb25 is offline   Reply With Quote
Old 12-11-2010, 02:35 PM   #6
underground_army
underground_army is an unknown quantity at this point
yeah i second that about the caster and for the shaking have you checked your balance on the tires, i mean 50mph is when a lot of cars start to shake.. well if im wrong someone please correct me
underground_army is offline   Reply With Quote
Old 12-11-2010, 03:58 PM   #7
ItaliaBrat
That is exactly what is happening I turn right and I feel he car wanting to go straight causing me to turn more to make the turn
Old 12-11-2010, 05:51 PM   #8
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Haha...why would you go on base for car maintenance shit. Guess you like getting ripped off compared to out in town.
CLICK HERE!!!
Old 12-11-2010, 06:10 PM   #9
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Send a message via AIM to hOngsterr
it can also be your tension rods.
thats what darin at westend told me about my car.
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
hOngsterr is offline   Reply With Quote
Old 12-11-2010, 08:29 PM   #10
S14DB
AFC #1
S14DB's Avatar
That's what we are talking about. They control your caster.
But, to be that far out he has to have some stuff bent.
Old 12-11-2010, 08:48 PM   #11
PoorMans180SX
PoorMans180SX's Avatar
Yeah the shop that did that should give you your money back. Your car is un-alignable until you get that fixed, and they know that. They just wanted to take your money.
Old 12-13-2010, 02:10 PM   #12
ItaliaBrat
DAMN! lol Thanks guys for the info! Pretty pissed, IDK who to trust, and I sure as hell don't know everything about cars so would be difficult to work on my OWN daily driver!
Old 12-13-2010, 02:57 PM   #13
Datenshi
Datenshi is an unknown quantity at this point
Your frame might be bent as well, but we'll hope not and that its a tension rod. It would make more sense since your caster is fucked that its the tension rod, but its still possible.
If you have a bent *TIE* rod or tie rod end, not tire rod.. this would also be possible. If you have a bent tie rod, someone fucked something up and curbed the car, etc.
Datenshi is offline   Reply With Quote
Old 12-17-2010, 08:37 AM   #14
slim
slim's Avatar
slim is an unknown quantity at this point
have you upgraded your tension rods yet? if not some that are really badly broken could allow the caster to go way out. mine were so bad i could feel it pulling different ways through corners.
slim is offline   Reply With Quote
Old 12-17-2010, 02:16 PM   #15
iamtheyi
iamtheyi's Avatar
iamtheyi is an unknown quantity at this point
lol yeah. Something is bent. Buy new tension rods. Should help. Unless your car has been in an accident and the frames bent to shit. No fixing it then.
iamtheyi is offline   Reply With Quote
Old 12-17-2010, 03:35 PM   #16
Sileighty_85
Sileighty_85's Avatar
If you drove your car for a while before the alignment the tires might be severly worn causing it to pull since they wore in to the unaligned specs
Just a thought. but your probablem sounds a little more sever than that
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-31-2010, 12:23 PM   #17
ItaliaBrat
Any ideas on where to go to get this checked out?
Old 12-31-2010, 12:33 PM   #18
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
my car was crashed in the front left side. So my camber is -2.7 on that side and the right is -.7. And car still pulls to the rights. Thanks to whoever crashed mine -_____-
Old 01-01-2011, 01:21 PM   #19
jin8544
jin8544's Avatar
jin8544 is making his/her stupidity well-knownjin8544 is making his/her stupidity well-knownjin8544 is making his/her stupidity well-knownjin8544 is making his/her stupidity well-known
get adjustable tension rods and get it aligned again. you'll be fine. it is not the best way to adjust caster but it is cheaper than buying caster/camber plate which will cost around $400 bucks. And yes caster is the only problem. Camber only affects tire wear (in daily driving conditions)
jin8544 is offline   Reply With Quote
