Old 05-04-2010, 11:12 PM   #1
nismo619
nismo619 is an unknown quantity at this point
Question Greddy type RS vs. type R
i searched and couldnt find the answers i was looking for.
what is the big difference between the two ? I just bought a brand new type rs to replace my old bov and it surges once i boost to about 5 pounds then it flutters and bogs my engine until i let off some. i tightened it all the way tight and this didnt seem to help so i was thinking of getting a type rs cuz i hear they hold more hp? i have a t3/t4 topmount with external wastegate and built motor if that helps at all. thanks
nismo619 is offline   Reply With Quote
Old 05-04-2010, 11:32 PM   #2
idamaster
idamaster's Avatar
idamaster is an unknown quantity at this point
Adjust the spring via the Allen stud at the top.
idamaster is offline   Reply With Quote
Old 05-05-2010, 06:04 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Type-R BOV is bigger than any other Greddy BOVs out there. If you look at the flange, the opening for the Type-Rs are bigger.
I use it with a GT3582R boosting to 2 bar with no leaking issue.
CLICK HERE!!!
Old 05-05-2010, 06:54 AM   #4
sirfallsalot243
sirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enough
Ive heard of lots of people experiencing this with the Type S and Type RS's.
sirfallsalot243 is offline   Reply With Quote
Old 05-05-2010, 07:59 AM   #5
SoSideways
SoSideways's Avatar
The GReddy Type R BOV is the only one you should be getting. I've had this as my one and only BOV since 2003 and it's held up just fine.
Plus it's huge.
It means business.
Old 05-05-2010, 08:24 AM   #6
nismo619
Ok cool thanks guys I'm going to be trading my rs for a type r today to a buddie. so do you think this will stop the fluttering under boost? And are there any markings on the type r too look for to make sure its not a fake? Thanks again.
Old 05-05-2010, 10:39 AM   #7
SoSideways
SoSideways's Avatar
Don't think there are any fake Type Rs out there.
In any case, the fluttering under boost thing might not be BOV related, but instead fuel related or timing related.
You best check out all the other things that could be wrong before blindly changing out parts to try and fix your car... although trading out an Type RS to a Type R isn't exactly a bad trade in any circumstances.
Old 05-05-2010, 04:14 PM   #8
nismo619
idk where to begin checking. it sounds exactly like the bov and what is weired is is 1st and second it doesnt really do it and in third it starts and in fourth or fith i cant boost past a couple pounds. idk what it could be
Old 05-05-2010, 04:16 PM   #9
nismo619
and this motor just had some work done to the block and head
Old 05-05-2010, 09:25 PM   #10
SoSideways
SoSideways's Avatar
Sounds like the more load the engine sees, the worse it gets.
Old 05-05-2010, 09:56 PM   #11
HOBBS240
HOBBS240's Avatar
HOBBS240 is an unknown quantity at this point
Is the Greddy Type-R too much for a stock motor?
HOBBS240 is offline   Reply With Quote
Old 05-06-2010, 12:32 AM   #12
nismo619
but in first and second it doesnt do it. I traded for the type R and it still does it.I think it could also be my wastegate fluttering because now its stuck open, i can even hear the exhaust going through the wastegate at idle... i just bought a tial 38mm so maybe that will fix it but idk. it is deffinetly something turbo related. help me out ha ha
Old 05-06-2010, 06:41 AM   #13
fliprayzin240sx
If your BOV is stuck open then you will have a massive boost leak...you will know its stuck open because your car will run like absolute crap.
CLICK HERE!!!
Old 05-06-2010, 07:35 AM   #14
SoSideways
SoSideways's Avatar
Well, chances of 2 different BOV both being stuck open is pretty slim.
Possible, but highly doubtful.
If your wastegate is stuck open, that could cause what you're describing, since first and second don't really place much load on the engine, your turbo won't really boost much, but once you hit 3rd gear, there's enough load to make the turbo start spooling and making boost, and if your WG was stuck open, your turbo won't spool, but the ECU is already in the timing and fuel maps where it is expecting boost to be there, so that's why your car sputters and coughs and junk.
Old 05-06-2010, 10:35 AM   #15
alonroz
Trader Rating: (98)
alonroz is an unknown quantity at this point
Feedback Score: 98 reviews
No, its adjustable to a very low threshold, it worked perfectly on my stock motor...
alonroz is offline   Reply With Quote
Old 05-06-2010, 08:11 PM   #16
nismo619
ok so i installed a new tial 38mm and the type R bov , and it is still doing it... the bov isnt tightened all the way, more like half so im going to tighten it more once i go somewhere, but the engine doesnt really sputter unless i try and step on it while its happening, and the bov isnt getting "stuck" open its fluttering opening and closing.
Old 05-06-2010, 08:12 PM   #17
nismo619
and let me remind you i am making 400hp with my setup
Old 05-06-2010, 08:30 PM   #18
fliprayzin240sx
K i re-read what you posted, you said you can hear the turbo fluttering and then the engine would bog? Have you pressurized the whole system to see if you have any boost leak?
CLICK HERE!!!
Old 05-06-2010, 09:08 PM   #19
nismo619
no idk how ?
Old 05-06-2010, 09:09 PM   #20
nismo619
i mean i checked th couplers and its deff not my intercoler its new
Old 05-06-2010, 10:08 PM   #21
Sileighty_85
Sileighty_85's Avatar
Where are you getting your Vac source from?
Check the lines for breaks and cuts or try switching the Vac source, Give it its own Vac source
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-06-2010, 10:54 PM   #22
nismo619
yeah im thinking its a vacum problem also, but my bov has its own vacum line from the manifold and the wastegate vacum line goes to my compressor on the turbo.
Old 05-07-2010, 07:59 AM   #23
SoSideways
SoSideways's Avatar
You need to do what Ray said to do and perform a boost leak test.
Just because your intercooler is new doesn't mean it can't have pin hole leaks and stuff. Friend of mine cheaped out when he was building his SC300 w/ a 2JZ swap in it, and bought some cheap eBay intercooler and eBay Veilside intake plenum knock off, and those turned out to have pin hole leaks from shitty casting.
In any case, buy yourself a PVC cap the size of your MAF, then drill and tap a hole in the middle of it for an air hose hooked up to an air compressor with a regulator on it, then just set the compressor for 10psi and let it go through that cap. Put that PVC cap where the MAF would have gone.
From there, listen for any air leaks. It would be very obvious as you will hear it leaking out from somewhere if it was a huge leak.
But if you don't hear anything, then start checking the entire length of your piping, intercooler, hoses, etc. just to double check.
Old 05-07-2010, 08:36 AM   #24
Sileighty_85
which port on the manifold?
S13 SR?
Stock Manifold or Greddy?
the bottom Port of the S13 TB doesnt create a Vac use one of the top ones
後輪駆動車1番
1986 SR86 - 200ish
Old 05-08-2010, 12:10 AM   #25
nismo619
ok so we did a couple tests today and are still stumped. we filled all the plumming with a smoke machine idk what they are called nut yeah... no leaks but this wasnt a high pressure test for boost leaks. we will be doing that monday cuz we didnt have the right things to do it. its weird it runs super rich when it does this too. we changed the timing several times and it didnt seem to fix it. we think it has a boost leak so like i was saying first thing monday we are going to do the test. and my fpr vacum line is on the tb nipple, is this bad ? i only have one nipple on the manifold right now (greddy mani) and i didnt want to Tee my fbr,bov,and boost gauge all together like they were so thats why i did that. think of anything else maybe ? its weird that it runs rich when it sputters its like the air is leaking but the fuel is still getting there...
Old 05-08-2010, 05:45 AM   #26
fliprayzin240sx
That definitely screams boost leak right there...
CLICK HERE!!!
Old 05-08-2010, 05:58 PM   #27
nismo619
thats what im saying ! lol but i dont have the stuff to presurize it though. this sucks!
im going back to the shop thursday to do the presure test but i dont want to wait that long...
Old 05-08-2010, 06:09 PM   #28
Unique
Unique's Avatar
Unique has a spectacular aura aboutUnique has a spectacular aura aboutUnique has a spectacular aura aboutUnique has a spectacular aura aboutUnique has a spectacular aura aboutUnique has a spectacular aura about
I was having a similiar issue, just added a stronger spring to my bov and it solved the problem.
Unique is offline   Reply With Quote
Old 05-08-2010, 06:19 PM   #29
nismo619
ok well my typr r thats on it was over half tightened but i guess ill tighten it all the way and see what happens. i have a tial q but need to get the flange welded on.
Old 05-08-2010, 06:23 PM   #30
nismo619
ok this might sound like a stupid question but, if i am under the hood and rev my engine and the bov stays closed and i feel no air come out is that too tight ? when it was stock it would blow off...
and this also might be a dumb question but, when i shift and the bov flutters instead of making the pshhhhh sound doesnt that mean its too loose ?
