![]() Join Date: Feb 2004
![]() ![]() ![]() Feedback Score: 6 reviews
I'm trying to decide between these two systems to finish off my S14 SR20 build. I see advantages and disadvantages of both parts though...does anyone have experience with these?
My goals are usable power and corrosion resistance is important (even though I won't be driving my car at all during the winter). GT Spec Advantages: -Full stainless construction -Max high end power Disadvantages: -Single muffler (not my favorite look) N1 Dual Advantages: -High end power and increased mid-range power -Dual muffler (more my style) Disadvantages: -Mild steel construction (up to muffler), although it is titanium particle coated. Basically, for the mid-range power and style I would go for the N1 Dual hands down if it was full stainless. Any helpful opinions?
![]() Join Date: Aug 2005
Are you actually going to order the Apexi.... or the apexi style wanna be ebay muffler..
Unless you plan on keeping this for 10 more years either has enough corossion resistance. Neither one makes more power. If you think mufflers are going to tune "power curves" then you should probably quit reading super street.
Eye on the Prize |
![]() Join Date: Dec 2002
The N1 Dual has horrible ground clearance. Add that to your thoughts before buying.
![]() Join Date: Nov 2004
Dual N1 is a huge piece of shit. It sits low, yet some portions were sitting too high and hitting my driveshaft/undercarriage. I had the exhaust for a week before I took it off.
Shit, the SSAC ones fit better then the Dual N1's they were designed after.
#5 | ||
I believe the GT spec sits rather low as well. Expect to have ground clearance issues if you're slammed on either exhaust, or any for that matter...
My SR20VET |
![]() Join Date: Mar 2009
i have the N1 Dual and Yes its sit low if ur Slammed DONT BUY em Be honest i wish i never got em and just took my Car for a Custom 3 inch exhaust would of saved me 300 bucks and i wouldnt care everytime i Scrap them going over Drive ways and What not
Man w/ CTSV & a Car Seat
So you think GT-Spec is awesome because of the over-rated piping sizing? Just to let you in the lil joke about it, ask them what size the resonator is. The fuck is the point of having 90mm pipes when the resonator you have chokes the fucking exhaust up with its 75mm inlet?
You want big piping...Kakimoto exhaust bar none... |
![]() Join Date: Apr 2009
just go Buddy Club Spec II, it sounds sexy as hell on an SR and cant go wrong with the piping on it
What did the egg say to the boiling water? It will take me a while to get hard I just got layed last night |
![]() Join Date: Dec 2003
Blitz Nur Spec R is what I've settled on BUT....I replaced the resonator with a straight pipe.
Solved my ground clearance problem and sounds amazing!
#11 | |
Been there, done that...cut the flange out too and make it into a 1-piece exhaust. My old S14 was slammed so low that when I change lanes on the freeway, that flange would catch road reflectors ever so often...
Zilvia Contributor
![]() Join Date: Oct 2001
![]() ![]() Feedback Score: 1 reviews
I have the Apexi dual for my S13 (yes, not s14) and it sits low...but if you switch to aftermarket urethane exhaust hangers and have all the exhaust bolts tightened to hell with airtools on a lift it helps clearance a bit. I know you dont use "cheap" parts but the SSAC N1 dual is supposidly full stainless and folks here say it fits nicely. Also, have you looked at any oval canister exhausts? (ex mag, realize tt) I think their looks are way better than standard fart cans. A few years ago i saw a special exition realize tt offered in full stainless.....there may be some blitz dealers with that available as new old stock. Good luck with your search.
400x200
![]() Join Date: Oct 2009
I have the the Apexi GT spec on my 14. I dont know what you guys are talking about. The GT spec has great ground clearance and the resonator does not choke the exhaust. The exhaust piping starts at 3", then after the resonator it goes to 3.5", then 3.75" right before the muffler.
Also the GT spec sounds great, nice low tone |
#15 | |
Good words of advise, they help astronomically when compared to the worn rubber ones. CS makes a set for under $20 I think.
Great feedback on the exhaust. I have a s13 with a s14 sr w/ the gt spec I think the exhaust is great.
After I installed it I saw huge difference in mid range. But I agree about the ground clerance it sits to low by the resonator I hit a good couple of times so I reposition the piping haven't had a problem since. Then again my car sits low so it alson Depens on the ride height of ur car. |
#17 | |
What do you mean by low? I am going to running the Apexi GT also, I just want a gauge of how low i can go before clearance is an issue. I.E. road reflectors, speed bumps, reversed spike strips (I tore up 2 SSAutoChrome caniisters on those). I am hoping that it will all work out for a good balance between clearance and nice stance, lol.
![]() 1989 240SX - 1JZGTE | Stance | Apexi GT | LMGT2 |
