Old 12-10-2011, 09:04 AM   #1
TerrySilysacks
TerrySilysacks's Avatar
TerrySilysacks is an unknown quantity at this point
cross threaded nut on a lose stud
my problem is, how do i break it, the lug nut is cross threaded on the stud and the stud is spinning lose on the hub which makes the stud and nut spinning the same time.
things ive tried
put presser and break with a cheater bar-fail
take the socket 19 and break it lose-fail
tried beating on it-fail
impact gun-fail
so i fail and fail and fail
S.O.S
TerrySilysacks is offline   Reply With Quote
Old 12-10-2011, 09:15 AM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Same way it got cross threaded, impact gun.
CLICK HERE!!!
Old 12-10-2011, 09:16 AM   #3
TerrySilysacks
tried that too. nut is spinning with stud
Old 12-10-2011, 09:35 AM   #4
Mercury_Hg
Mercury_Hg is an unknown quantity at this point
Originally Posted by TerrySilysacks View Post
tried that too. stud is spinning with it still
There's nothing you can do, man, except sell your car for scrap. I'll give you about $3.50.
Would torching it first help?
Also is the stud pressed in all the way, or is the nut all the way back? If not beat it out as far as you can and grip the backside with locking pliers before wrenching on it.
Mercury_Hg is offline   Reply With Quote
Old 12-10-2011, 10:17 AM   #5
TerrySilysacks
its stuck between a 25mm spacer. and stud was press in and suddenly pop out some how. i cant even get a vice grip on it aka locking pliers
Old 12-10-2011, 10:34 AM   #6
S13.75DET
S13.75DET's Avatar
S13.75DET is an unknown quantity at this point
is the wheel still on? If yes, i would turn the wheel all the way to one side and use an oxy-ace torch to cut the back of the stud off. or a hack saw if you can get it to fit. or attach a chain around your wheel and hook up to a truck and yank it off lol
if no you can use a locking adjustable wrench to hold the nut while you a cutoff wheel on an angle grinder or hacksaw to cut the studd in half, or you can remove your entire hub assembly and have the stud pressed in with a table vice, or c-clamp so you can try to get the nut off....
S13.75DET is offline   Reply With Quote
Old 12-10-2011, 10:35 AM   #7
S13.75DET
S13.75DET's Avatar
obviously the stud wasn't pressed in correctly also
Old 12-10-2011, 06:51 PM   #8
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
you can bend or tear the dust shield in the back side of the rotor and then weld the stud onto the hub. make sure you weld it good enough so that when you try to gun it off, the stud stays in place. once you get the wheel off, you can grind the weld off of the stud.
rcdad123 is offline   Reply With Quote
Old 12-10-2011, 06:55 PM   #9
Sileighty_85
Sileighty_85's Avatar
Drill it out
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-11-2011, 07:45 PM   #10
c_mancuyas8
c_mancuyas8's Avatar
c_mancuyas8 is an unknown quantity at this point
^^^This. Ive had the same prob before and this was my last option but it worked. If you dont have a steady hand I hope you have cheap wheels!
c_mancuyas8 is offline   Reply With Quote
Old 12-11-2011, 07:55 PM   #11
Darren
Darren's Avatar
Darren is an unknown quantity at this point
I had to do this once, worked good... wasn't an issue for me cause i just upgraded to 5 bolt anyway
Darren is offline   Reply With Quote
Old 12-11-2011, 09:31 PM   #12
holemilk00
holemilk00's Avatar
Trader Rating: (33)
holemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the rough
Feedback Score: 33 reviews
If you can get to the back of the stud, put a small spot weld on it. Once you get the lug off, cut the spot weld and change the stud.
I had a cool signature
holemilk00 is offline   Reply With Quote
Old 12-11-2011, 09:58 PM   #13
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
cut the stud and replace
idahotuner is offline   Reply With Quote
Old 12-12-2011, 04:18 PM   #14
RandallSharp
RandallSharp's Avatar
RandallSharp is an unknown quantity at this point
I've had this happen. We just used an impact gun to basically split the lug in two. It takes some time, but then the lug comes right off and you can push the stud through the back.
1991 240sx Hatch Daily'd!
RandallSharp is offline   Reply With Quote
