Just got another SR and the front of it is covered in oil that had been leaking out from somewhere. Can't really tell if its from the front main seal or around the front cover. Would you replace the whole oil pump assy or just the main seal?
![]() Join Date: Dec 2006
Probably the main seal
Just check the cover for cracks, if none are found just replace the seal
![]() Join Date: Jan 2008
lol i JUST did this a few hrs ago.
sprayed the front cover with brake cleaner. wiped it down nice and clean. started her up. revved it a little.. and watched oil run down that cover from behind the pulley. FML |
![]() Join Date: Apr 2006
![]() ![]() ![]() ![]() Feedback Score: 6 reviews
It's behind the crank pulley man. Remove whatever you have to in order to get it out safely.
Rent a pulley puller you will need it. Leave the crank pulley bolt threaded partly in while setting up the puller so it has somewhere to put force in the center.
