![]() Join Date: Sep 2011
![]() Feedback Score: 20 reviews
car wont shut off s14 swap into s13
checked and have swapped relays with know good ones, including the (Brown relay) located behind the driver side kick panel. if I remove it, it obviously turns the indicators off on the instrument panel.
BUT if you remove the key the car stays running. I noticed at the grey plug that is located close to the passanger side engine bay, 2 pins have power at all times key on or key off (still has power with ignition switch disconnected) there is supposed to be ground when the I/g switch is off and power when its on. ecu has been swapped with 2 newish ones. relays have been checked I googled it, even started unplugging shit and still power is always present. anyone have any ideas on where to look next? s14 swap into s13 wiring specialties harness newish. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I have done many other swaps and this has never happened wtf?????
GO DUCKS!!!!!!!!!
#2 | |
GM2 (SW/AW)
http://www.google.com/search?hl=en_U...ap&newwindow=1
Rather than post every link, take another look. The ignition switch only goes to so many places.
I would like you to know that I read about half those already.
and still have not found the solution to my problem and I followed them word for word. thank you for you response.
GO DUCKS!!!!!!!!!
Have you checked power at the ignition switch? Have you worked through the FSM to follow the flow path of power? Contacted Yuri at Wiring Specilaties? He could have some insight for you.
My SR20VET |
