ARP headstud installation...How???
I'm at the point of my build where I need to put the ARP headstuds into my s14 sr20det. This will be a first for me and the search yielded absolutely no results so here I am.
How do I install these into the block? |
![]() Join Date: Dec 2003
Its called an Hex Key..... Are you sure you should be doing this?
If they don't break free with a little bit of effort, smack the top of the stud with a metal hammer. DON'T fuck up the treads and don't beat it down into your block. Sometimes they stick due to the difference in materials so a little shock will free them up.
I've got to poke fun a little, come on....
At least I gave you some good advice
well they're in now. I guess more than anything I was wondering what the procedure was...do I put on the moly assembly lube onto the end that goes into the block, do I put the head on first then the studs etc...
![]() Join Date: Dec 2006
i put the lube on the ends that you attach the nuts, and put teflon tap on the block ends.
1st. put on you head gasket 2nd. put in the 2 middle studs, the longest 2 3rd. put on the head 4th. install the rest of the studs 5th. begin the torque down process
here wichever one you can read
well my Instructions tells me Torque nuts to 70Ftlbs with ARP Moly Lube Or 85ftlbs with 30wt
also Due to expansion rate of aluminum it is recommended that the torque should be 65 ft lbs with ARP Moly Lube I torqued mine to 68ft lbs with the Moly Lube No problems after 2 years
#18 | |
![]() Join Date: Jan 2008
Location: Amerika24 alabama: Where if your not first..... your last
Thats sounds right ^
#19 |
where are ya'll getting 110 ft lbs from?
#20 |
![]() Join Date: Apr 2007
110 is wrong, Its to tight. Its 20, loosen, 40, loosen, 60, loosen, and finally 80. This is with arp moly lube. Thats what my arp instructions said.
#22 |
![]() Join Date: Sep 2005
Why are you scanning the instructions. That is what you NEED to fallow.
I also highly recommend using the ARP molylube over motor oil(what ever else u may use, especially Teflon tape).
#23 |
Scan as in scan them into a scanner and upload them to the computer. I'm definitely using the Molylube that it came with and I have no plans of using teflon tape.
#25 | |
![]() Join Date: Oct 2005
use moly lube and torque to what arp specifies ![]()
I build air pumps!
#27 |
so what if they are arp studs made for a VW engine. ive worked at an engine shop and all we did was VW superV, US F3, and offroad VW motors. you dont torque those to 110lbs anyways...
"seeing the problem", understanding why things are done one way or another, or reading forums are not all the same... ![]()
I build air pumps!
