Old 11-25-2007, 08:14 PM   #1
Prelude Guy
Prelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymore
Installing braided oil line question. Pics included
Hey guys,
I am trying to finish up my S15 T28 install. I purchased some steel braided lines. The install is going well until I got to the oil line. I am installing the fitting and I am not sure how much to torque it down. There seems to be a lot of threads showing even after it feels like it is tight. It's not too tight. It never gets to the point where it gets difficult to turn.
I compared the length of the new fitting to the old one. The aftermarket fitting is noticeable longer.
Instead of proceeding, I figured I would ask before ruining the turbo.
Here's the part I am installing:
http://i42.photobucket.com/albums/e3...olantline2.jpg
http://i42.photobucket.com/albums/e3...olantline1.jpg
That's the fitting installed to the point where it gets a little more difficult to turn. That's how much extra threads are left to tread.
Also, since I have you guys, is it common for the coolant line to be a little too long? Not sure why mine is so long. Seems like it's about ~4" too long.
Any help is greatly appreciated. I can't wait to get this turbo back on and put the engine back in my car.
Prelude Guy is offline   Reply With Quote
Old 11-25-2007, 08:24 PM   #2
slider2828
slider2828's Avatar
when it gets wrist tight... Start the car and run it... Check if there are leaks, if so tighten a little bit more..... Your main worry is stripping the block.... So trial and error
Turn and Burn!
Old 11-25-2007, 08:40 PM   #3
Slidin240Wayz
Slidin240Wayz's Avatar
Slidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfection
Forget trial and error.
Did you put "the white tape" (brain fart)
If so, hand tighten + .5 a turn.
You'll be set.
Slidin240Wayz is offline   Reply With Quote
Old 11-25-2007, 08:50 PM   #4
Wiisass
Wiisass's Avatar
Wiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond repute
Send a message via AIM to Wiisass
teflon.
Or there are different pipe thread sealants you can use. I like them better than teflon tape.
TIP Engineering
R/T Tuning
Drift and RWD Sport
DriftAssNation
Wiisass is offline   Reply With Quote
Old 11-25-2007, 08:52 PM   #5
Prelude Guy
Uh oh. What's the white tape? Where can I get it from? I saw one pic of soneone's SBLs with white stuff on the threads but I didn't know what it was. If it's a good idea...I will do it!
As for starting the car....my car hasn't run since I bought it.....3.5 years ago. My rebuild has been long and extensive.
Thanks for the help.
Old 11-25-2007, 09:15 PM   #6
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
You would teflon tape for a better seal and it also helps when you take the fitting off. If you are not leaking, then I wouldn't really bother with it.
You can find teflon tape at home depot or there is teflon paste you can find at pepboys.
Jung918 is offline   Reply With Quote
Old 11-25-2007, 09:28 PM   #7
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
Teflon tape is like plumber's tape to help seal threads from leaks. You can get it at auto parts store or Home Depot/Lowes.
When attaching regular fittings, you can apply one piece of teflon tape and put a copper washer for piece of mind.
For AN fittings, do not attach anything because the flare fittings seal themselves.
g6civcx is offline   Reply With Quote
Old 11-25-2007, 09:44 PM   #8
SixMachine
SixMachine's Avatar
SixMachine is an unknown quantity at this point
Honestly Forget the tape!! I don't use that stuff. I learned at my local speed shop that all the O.G. muscle car guys use "LIQUID TEFLON" for Earl's, Russel fittings for their nitrous bottles oil coolers and stuff like that. This stuff can be found at any auto parts store. Apply it like Thread locker or anti seize and your good. Seals good and is a even better piece of mind. It looks kinda of like a small tube of toothpaste
SixMachine is offline   Reply With Quote
Old 11-25-2007, 10:06 PM   #9
bwake 5
bwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura about
im willing to bet you have the line on backwards. turn it around and i am almost 100% sure that it will fit perfect.... lmk if im right.
there shouldnt be any thread showing on the turbo side.
bwake 5 is offline   Reply With Quote
Old 11-25-2007, 10:11 PM   #10
g6civcx
g6civcx's Avatar
Damn, I didn't catch that.
Old 11-25-2007, 10:15 PM   #11
bwake 5
???? am i right?
switch the fittings around.
Old 11-25-2007, 10:17 PM   #12
g6civcx
g6civcx's Avatar
???? am i right?
It looks like you are. AN fittings have a flared end, not a tapered end.
Old 11-25-2007, 10:22 PM   #13
bwake 5
Exactly .
Old 11-26-2007, 08:05 AM   #14
Prelude Guy
Hmm,
All I did was take the fitting out of the line and install it the way it was.
So the flat end of the fitting should be sticking out? The rounded end goes into the turbo?
All of the other fittings I have had the rounded end going into the braided line, and the flat part installing into the block. Are those wrong too?
Thanks for the help, guys!
EDIT:
Here's a pic of the lines EXACTLY the way I got them.
http://www.we-todd-did-racing.com/fi...urboLines1.JPG
Old 11-26-2007, 09:34 AM   #15
g6civcx
g6civcx's Avatar
If you're confused, compare the thread with the stock hardline banjo bolt. The pitch on the AN will be very different with a 37* pitch.
The other thing that could be is your thread is stripped. You'll need to retap it or weld a fitting on.
Does the banjo bolt thread in?
Old 11-26-2007, 10:29 AM   #16
bwake 5
Old 11-26-2007, 10:30 AM   #17
bwake 5
+1 .
Old 11-26-2007, 11:31 AM   #18
cotbu
cotbu's Avatar
Huh? what? this is not rocket surgery. Ask someone that has the circuit sport turbo lines installed with an sr20det and s15 spec R turbo. Oh i do.
Hmm,
The way you had them is correct! My restrictor is on the turbo then line then banjo fitting on the block. I thought it would be trouble using the banjo fitting, but you never touch that bolt again. As for the water line there self-explanatory. The end with the screw clam is not going on the turbo without a new fitting.
Also if you look at the stock line for oil feed it does not sit flush with the turbo, at least mine had threads showing.
Sir, your lines are a bolt on upgrade, you need a restrictor for BB turbo's
I feel like HOUSE!
Old 11-26-2007, 12:00 PM   #19
bwake 5
my lines looked exactly as posted in the pic.i also hooked mine up exactly as i posted in the pic..... no threads are showing. and everything bolted up flush,
Old 11-26-2007, 12:06 PM   #20
Prelude Guy
Again, thanks for the help guys!
However, now I am even more confused.
I THOUGHT I figured out how to install the lines, then I saw this pic.
http://img476.imageshack.us/img476/8871/1000589yi4.jpg
From this thread.
#/f/showthread.php?t=159072
This pic is exactly how I thought the lines were to be installed. He's using the flat end of the oil line like I am too on the turbo.
I thought the silver metal line with the banjo bolt opening connects to the block using the OEM oil restrictor bolt to secure it to the block. I thought the opened ended braided line (the one with the red fitting at the end) connected to the back of the block to the coolant line.
Thanks!
Andy
Old 11-26-2007, 12:10 PM   #21
bwake 5
on my steel braidedd lines the banjo bolt went to the turbo and the 90 degree angle fitting went on the block.
and my pic is off because i didnt notice that your coolant line was open on one end.... due to the fact that both my coolant lines had 90 degree fittings tapped straight into the block not open.
Old 11-26-2007, 12:16 PM   #22
HellonFire
HellonFire's Avatar
HellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud of
Send a message via AIM to HellonFire
I always install them exactly as you did. Works for me everytime.. I think I do have a little bit of threads showing.
Tyler
HellonFire is offline   Reply With Quote
Old 11-26-2007, 12:21 PM   #23
Prelude Guy
Tyler
Did you coat the threads with anything too? How much did you torque it down?
Old 11-26-2007, 12:26 PM   #24
HellonFire
HellonFire's Avatar
I use teflon tape. I just go until it feels hand tight, then about a half a turn more. Then crank it up and check for leaks. If leaking, obviously tighten a little more. But be careful not to strip.
Tyler
Old 11-26-2007, 12:30 PM   #25
bwake 5
I use teflon tape. I just go until it feels hand tight, then about a half a turn more. Then crank it up and check for leaks. If leaking, obviously tighten a little more. BUT BE CAREFUL NOT TO STRIP.
Tyler
i underlined the important part lol
Old 11-26-2007, 12:32 PM   #26
HellonFire
HellonFire's Avatar
Yes, most important. Especially into the block. Oh god I hate that oil fitting into the block. I've probably stripped 5 now from being in a rush.
Tyler
Old 11-26-2007, 12:34 PM   #27
MegasquirtCA
MegasquirtCA's Avatar
MegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfection
Some of you guys are Amazing. He has the fittings on correctly like mentioned by cotbu. The oil inlet is FLARED to begin with so the A/N side is supposed to be up.
Dont even bother with Teflon tape, the oil inlet is flared like a A/N fitting but it also has a extremly tiny oring on it. Putting Teflon will probably burn up from the intense heat.
See the flare fitting. This is MY S15 turbo.
This is my oil line they are 4AN fittings on each.
You coolant lines are fine. Your good. The oil fitting tighten it but dont go crazy.
By the way this is on a CA18DET, the only difference is that my CA uses a different thread on the engine block fitting which is M12x1.00 opposed to SR's M12x1.25.
You can barely see my oil feed line.
MegasquirtCA is offline   Reply With Quote
Old 11-26-2007, 01:14 PM   #28
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
Top one - I use mine exactly opposite - fits better.
middle is wrong - the one labled turbo goes back behind the motor to coolant line.
bottom might be right? - altough I use all AN 90* fittings and not banjo.
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 11-26-2007, 01:22 PM   #29
bwake 5
update:
top one- fits better like i posted. ( i use enjuku lines idk if they are different
middle one- is wrong becuase the enjuku ones are tapped into the block for s14 motors with a fitting. so for his and your application. your right wrong. i apologize, it is right for my s14 motor
bottom one-right
lol
Old 12-01-2007, 01:24 PM   #30
Prelude Guy
Thanks for the help guys.
I was finishing up the install of the lines, and now I have another issue. The actuator bar that crosses this fitting is rubbing:
It hits the fitting a little, enought to cause friction...so it has to be fixed.
I tightened the fitting as much on the turbo as i can. Still not enough clearance between the fitting and the actuator bar.
Any ideas?
