I was wanting to put a pair of overfenders on my coupe but I didn't want to rivet them on and I didn't want to mold them because of track days. I searched and came up with this idea. Nutserts! You can get them on ebay as a kit in standar threads or metric threads. I chose metric M6 threads (the same thread that most of all the 10mm bolts are on the chasis). This is how it works.
Pick where you want the nutsert with a drillbit the size of thescrew you're using. Drill through the fiberglass and through the metal. Now get a bit that is the size of the nutsert. Now remove the fiberglass piece and drill out the small hole in the metal with the larger bit. Now screw the nutsert onto the special rivet gun. Insert the nutsert. Now squeeze the handles just like a regular pop rivet gun. Unscrew the threaded shaft. Place fiberglass piece back and line up hole. Screw into place. Done! I did my sideskirts also for daily driving but in track events I will remove them and just use zipties. If I didn't and snagged a cone the sidskirt would tear to pieces. In the pics the hex screws are not stainless. You need stainless so they won't rust. Also I bought this kit http://cgi.ebay.com/ebaymotors/METRI...spagenameZWDVW . This kit comes with 12 of 4 sizes. Last edited by C. Anderson; 07-05-2008 at 11:34 PM.. |
#2 | |
![]() Join Date: Nov 2006
hrm. so basically its like a rivet except not permanent...
or tapping a thread into the body kind thing.
![]() Quote:
![]() Join Date: May 2007
that's cool... never seen that kind of thing before... it's like helicoil kinda deal for body work
<------ Grumpy Old Asshole MY REVIEW THREAD: Ltdnismoracer4=DOOK #/f/showthread.p...ltdnismoracer4 |
![]() Join Date: Jan 2005
Go to Mcmasters car http://www.mcmaster.com/ search nut serts. They have all the specs on how much they stick out, how long and such. |
I'm getting stainless screws soon and the nuserts are zinc plated. Here are some more pics. They sit super flush and don't leak at all.
Admin Asshole
![]() Join Date: Mar 2002
Steal: to take without the owner's consent
Steel: an alloy of iron with small amounts of carbon; widely used in construction Class dismissed. 95drifto, nice how-to. I use products very similar to these on our aircraft and I often wondered about using them for an automotive application. Good stuff. ![]()
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
#17 |
Admin Asshole
I guess everyone is entitled to their own opinion.
#20 |
I mean I like the idea, I have never heard of this stuff. I think it looks good for what it is, but I dont know, I am a fan of seamless integration ESPECIALLY in body work. I understand that it works for removal, but I guess If I were to track my car, I would not worry about body in the first place. Thanks for introducing me to these nifty pieces of hardware though.
PLEASE post pics when paint/stainless is installed, I would really like to see the final product.
I was going to, but I can not think of a sig less than 75 characters. |
#21 |
![]() Join Date: Apr 2006
man i use those things for SOOOOOOOOOOO much stuff
used them to mount my diffuser and splitter, center console, and a few other things. my aero will be held on by them as well
2015 Subaru Outback Overlander - Wagonofdoom |
#22 |
![]() Join Date: Mar 2004
depending on the size, you might also be able to use aluminum screws, which you may be able to get in a color closer to your body work.
I dont think this will matter much for the OP, since his body work appears to be prety silverish, where stainless wont stand out much, but for other people with other colored body work, or for other applications, it may help out.
Buy the best, none other compares!
#23 |
![]() Join Date: Apr 2003
i own two of these things and i never even thought to use them. I used them all over my interior for mounting my wiring harness stuff and coil packs, but now i have a new use, also you can get smaller 6mm hardware for them and use alum machine style screws.
http://www.forcedfabllc.com/ |
#27 |
Why do they have to be riveted or epoxied on? Rivets get loose over time and you have to replace them. Also if I were to break one I just paint it drill holes in it and screw it on instead of drilling 20 rivets out and re riveting.
#28 |
![]() Join Date: Oct 2006
#30 |
![]() Join Date: Jul 2007
Trader Rating: (106)
If it is riveted and glued (with the right glue) and done correctly the rivets will NEVER come loose. If you break the 1/4 panel it is pretty much the same amount of work to replace it. I mean it takes what, like 10 mins max to drill out the rivets? It is a good idea for the sideskirts as it would be nice to be able to remove those to jack up the car or prevent damage at a drift event. I just don't see a point to the 1/4 panels and on top of that it looks like crap IMO.
