Old 07-30-2008, 10:25 PM   #1
lol_1337
lol_1337 is making a name for him/her selflol_1337 is making a name for him/her self
S13 Headlights stopped working??
Hey guys I searched all over for this topic (and if someone already posted about this, if someone would refer me to the thread I would appreciate that) for a bit but couldn't find any solution to my problem.
Recently I was driving at night and my right headlight stopped working.
In the morning I tried switching bulbs to the left and both lights work, so I guessed a wiring problem.
Then just tonight my left headlight went out. Anyone know what I should do? Do I have to cut into the harness to look for the problem, or is there a way I could redo the entire wiring? A diagram would be nice, thanks ; or a solution to this >.>;
The actual lights (bricks) are fine, anyone else get this problem? What should I do?
Edit :
Headlights pop up.
Turn Signal Lights work
Actual lamps don't work.
lol_1337 is offline   Reply With Quote
Old 08-01-2008, 10:27 AM   #2
irax
irax's Avatar
did you try checking the fuses?
I have the same problem but my fuses are good, it is a wiring problem.
Old 08-01-2008, 11:10 AM   #3
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
For any issue on S13 headlights, you should check the combo light switch first. Most likely that sucker is defective and not sending current to the bulbs.
g6civcx is offline   Reply With Quote
Old 08-01-2008, 11:25 AM   #4
ZX88
ZX88's Avatar
probably a fuse its the fuse box in the engine bay on the passenger side if not its ur switch here is a write up i did and it fixed my issue.
#/f/tech-talk/145000...-write-up.html
Old 08-01-2008, 11:31 AM   #5
memo92
memo92's Avatar
memo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfection
Head light harness
Are you using hi wattage hologen bulbs? If so, they tend to melt and deform the headlight plugs. You can pick some descent harnesess' off of 240s at a pick-a-part junkyard. No cutting needed, all you do is work your way to them and pop some harness ties that are plugged into the front clip. Install them in the reverse order that you take them off.
Check it out.
memo92 is offline   Reply With Quote
