| Media Forum / Pictures / Videos Forum dedicated to media, such as pictures and videos. |
B13 project pics.
I know that this is a mostly RWD forum but I figured I would put some pics up of the B13 that I am working on right now. In fact I do not own a RWD car at all...lol.
I also own a G20 and a 200sx SER that is getting a HUGE SR20VET build. Anyways on to the pics. When I picked it up. On the trailer. and cleaned up the engine harness except for the MAF plug which I need to re-solder. Then started work on it. Motor is out PS is out Charcoal canister gone AC out Degreased and pressure washed engine bay Put Davids (PwrdByUncleBens) old hood on (reverse panda) ]http://img.photobucket.com/albums/v338/91sentra01/100_0088.jpg[/IMG] |
Installed:
New front and rear main seals Newer VE water pump New tensioner gasket IACV gasket Pics. Old seal and a bit dirty Seal Puller and grease Coming out Cleaned Seal with a very light coat of grease on inside and outside. Seal in. Putting crank back on with rubber hammer and large socket. New ACT Unsprung 6 puck. Disk with my almost new Exedy Pressure plate. Disc on alignment tool and home flywheel resurface. Thread locker on bolts Then I picked up a set of 16" Konig Traffiks from Craigslist which I happened to stumble upon late one night while I was drunk. (BTW I love these wheels) They are good looking and very light. Its just too bad they are not made any longer. when I picked them up... curbed...dirty....scratched. Not very pretty. One pic of one where I repaired the rash and blasted it mostly clean. These wheels are going to get powdercoated candy teal much like these JLines. So the wheels are getting coated finally next week. I decided to stick with candy teal just because I like the color and I could give a damn if others dont. ![]() Here is a good pic of the engine bay that my boy took with his Nikon. Mods. Highport SR20 GT28R GTIR piping with Spearco cooler Greddy RS BOV G20 1" Auto radiator with slim fan and water wetter Calumsult ECU 370's at 4 bar GTIR ported manifold wit Ext. wastegate flange SR20VE valve cover 40MM tial external wastegate. N60 MAF (on its way) Prothane Motor mounts ES shifter and stabilizer bushings 3 inch downpipe 3inch VRS exhuast to Magnaflow muff. Equus guages- boost, water temp, oil pressure mounted in DIN slot Removed AC, and powersteering using a 25" belt and no tensioner Battery relocated in the trunk etc. etc And that is it so far. Today I am scrubbing up the wheel well area and getting off all the old grease that has been caked on over the years. Tackling some shady wiring that needs to be re soldered and heat shrinked. Ill try and keep this updated Last edited by TheRealNighthog; 07-05-2009 at 03:08 PM.. |
Thanks. Right now that is the best part of the car. I do try to take my time with things but as it is its hard to keep my mind on something when I have 2 projects going on at the same time.
The body is rough. In spots it looks like it was sanded with 40 grit paper then painted right over. Right now though I'm focusing on the drivability aspect of it IE suspension, chassis etc. I just replaced the tie rods and ball joints with moog parts and that in itself made a huge difference since I doubt they have been replaced since the car rolled off the line in 1992. My suspension will be simple but effective on this car. Progress/tein coils progress rear sway ES bushings and a few other bits here and there. |
![]() Join Date: Dec 2007
Man, I love B13's. I had built one myself, and then sold it later. I had a JDM SR20DE with a Bluebird T25 setup. LOVED that car. The suspension was gen 2 Hyperco springs with AGX shocks.
